#1 Gear box oil.
Posted: Thu Sep 12, 2019 9:58 pm
by Pbirty
Hello guys.
I'm looking for a bit of advice on changing my gearbox oil. I have looked into it a bit but getting varying answers on the best oil to put in there. It's a 1962 3.8 fhc with correct factory fit 4 speed moss box.
Thanks in advance Paul.
#2 Re: Gear box oil.
Posted: Thu Sep 12, 2019 10:59 pm
by rswaffie
Redline MTL.
Used it in my Healey 3000 moss box and now in my 63 FHC. Once warm, really helps the gear changes and makes it a nicer box to use.
#3 Re: Gear box oil.
Posted: Fri Sep 13, 2019 11:16 am
by Heuer
#4 Re: Gear box oil.
Posted: Fri Sep 13, 2019 1:06 pm
by lopena
I recently switched to Redline MTL in my ‘64 OTS Moss gearbox and noticed a marked improvement in shifting.
Be forewarned, however, that if your gearbox has any leaks they are likely to get worse with MTL.
Alan
N.J.
#5 Re: Gear box oil.
Posted: Fri Sep 13, 2019 2:25 pm
by Philk
lopena wrote: ↑Fri Sep 13, 2019 1:06 pm
Alan
N.J.
I would reinforce this. For some strange reason, whilst Redline MTL has a higher viscosity (75/80) it is very, very thin when cold. As such, any seepage you would have from the seals with thicker gearbox oil will be exacerbated with MTL.
#6 Re: Gear box oil.
Posted: Fri Sep 13, 2019 2:45 pm
by Heuer
It also takes a few hundred miles before you notice any benefits to shifting. Most people say the same but no one can come up with an explanation as to why
