Help
RichardF
#1 Help
Post by RichardF » Sat Mar 27, 2010 6:27 pm
My boot catch has failed (while the boot lid is locked down). Has anyone got any ideas on how I can open the boot??? The cable is still attached.
Post by christopher storey » Sat Mar 27, 2010 7:42 pm
Richard : you don't say what car you have . If it is a FHC or 2+2, then you will have to get into the rear compartment from inside the car ( I hope you're more athletic than me) and then take off the catch cover - 4 screws- after which you should be able to release the catch with a screwdriver. You will have to experiment a little to find which lever you push/pull, but if you can reach it pushing the lowest lever towards the front of the car should open it
If you have an OTS, then on the horizontal undersurface just to the rear of and above the number plate, there should be a hole, pobably covered with a bung. This gives access to the catch, and enables it again to be released with a screwdriver
Best of luck
Post by 1954Etype » Sat Mar 27, 2010 8:41 pm
[quote="christopher storey"]Richard : you don't say what car you have . If it is a FHC or 2+2, then you will have to get into the rear compartment from inside the car ( I hope you're more athletic than me) and then take off the catch cover - 4 screws- after which you should be able to release the catch with a screwdriver. You will have to experiment a little to find which lever you push/pull, but if you can reach it pushing the lowest lever towards the front of the car should open it
Best of luck[/quoteChris is right about the acces hole under the numberplate. However, if you haven't got one, you should be able to remove the offside rear light cluster. That should reveal the cable/catch
Post by Heuer » Sat Mar 27, 2010 10:13 pm
You may have to remove the number plate to get to the access hole. Jaguar also said you need to use a right angle bend tool (think Allen key) to operate the latch. I think the details are covered in the Owners Handbook or Service manual
daverawle
Post by daverawle » Sun Mar 28, 2010 9:10 am
Heuer wrote:You may have to remove the number plate to get to the access hole. Jaguar also said you need to use a right angle bend tool (think Allen key) to operaste the latch. I think the details are covered in the Owners Handbook or Service manual
My '63 is 'sans hole' so I have a string from the latch to the offside light cluster just in case.
1963 OTS
RichardF
#6
Post by RichardF » Sun Mar 28, 2010 6:49 pm
Sorry it is a Series 1 4.2 OTS.
RichardF
#7
Post by RichardF » Sun Mar 28, 2010 6:51 pm
That is excellent. Thank you for the information - I was thinking much more drasticly.
Post by Heuer » Mon Mar 29, 2010 12:56 pm
RichardF
#9
Post by RichardF » Sun Apr 04, 2010 5:41 pm
Thanks for the advice. This worked perfectly and all is now working properly.
