Series 1 2+2 Engine Advise
#21 Re: Series 1 2+2 Engine Advise
Post by mgcjag » Thu Feb 06, 2020 5:41 pm
Hi Chris..I assume they must have replaced the complete mainshaft with one from an overdrive gearbox...as you cant just take the tail section off a 2+2 box and bolt on an o/d....anyway...it all looks good...yes your probably correct re the prop..its the same length if you replace the 2+2 manual box with an o/d box.....Steve
69 S2 2+2 (just sold) & Building a C type replica, 1960 xk150fhc
baldyz1
#22 Re: Series 1 2+2 Engine Advise
Post by baldyz1 » Mon Feb 10, 2020 9:20 am
Yes you are right the whole main shaft was replaced.
Chris C
1966 4.2 2+2 Gun Metal
Jag3681
#23 Re: Series 1 2+2 Engine Advise
Post by Jag3681 » Thu Oct 14, 2021 4:38 pm
Hi all, been a while.
The car is now fully painted, 4.2 engine rebuilt but I'm stuck on the gearbox end
There is this on ebay. With your extensive knowledge what am I looking at work and cost wise to get this up and running and in the car
https://www.ebay.co.uk/itm/264599065181 ... Sws5BaZykr
Thanks in advance!
Tom :thankyouyellow:
P.S I'm literally on here daily for tips along the way with the rebuild, I honestly cant thank you all enough for your in-adverted help!!!!
Jag3681
#24 Re: Series 1 2+2 Engine Advise
Post by Jag3681 » Thu Oct 14, 2021 5:12 pm
I should add I do still have my gearbox from a 3.8L manual S1 if thats possible to use
