Ok so I have 6” rims and 205/70 rubber. The Avon CR6ZZ kind so soft
I’m getting inside edge wear on the fronts. I’m told this is because the geo should be set up differently when running wider bits?
Is this right?
Thx
Tyre wear
#2 Re: Tyre wear
Check your toe in.
joexke@yahoo.com
#3 Re: Tyre wear
Run your hand across the face of the tread from inside to outside and in the opposite direction. If you feel a feathe-redge in one direction you have a toe-in issue. Either way you should check for worn/loose parts and have alignment checked.
#4 Re: Tyre wear
If the toe in is within limits, check the ball joints, especially the lower ball joints.
#5 Re: Tyre wear
Thanks chaps.
No feathered edges and all ball joints recently renewed.
S1 4.2 Roadster in Resale Red
#6 Re: Tyre wear
Actually, there is very slight feathering.
