Bonnet balance link
peters3103
Topic author - Posts: 500
#1 Bonnet balance link
Hi gents,
I’ve removed my bonnet balance links for cad plating (now painted body colour). Will I need to fully disassemble them by removing the rivets? If so, how can I re-rivet them. I’ve never done it before
Cheers,
Cheers,
#2 Re: Bonnet balance link
Pete:
While there are dedicated tools to set rivets, the process can easily be achieved with the simplest of hand-tools (a hammer).
The toughest bit is to find the proper-sized solid steel rivets themselves...spend some time on the internet and you’ll find the proper size eventually (you may have to buy a dozen or two).
Once you have the proper size rivets get a propane torch and heat a rivet until it is orange-hot. Slip it into the hinge, put the hinge on an anvil with the rivet head facing down and give it a few almighty whacks with a ball-peen hammer to mushroom the rivet. Apply a touch of paint and job done.
Good luck,
Alan
N.J.
Good luck,
Alan
N.J.
#3 Re: Bonnet balance link
The difficult bit is not making it too tight !
Barrie
Barrie
#4 Re: Bonnet balance link
Barrie is correct...do not mushroom the tip of the rivet too much. An over-tight rivet will prevent the hinge from operating. You’re not building a bridge...no need to totally flatten the rivet.
Alan
N.J.
Alan
N.J.
#5 Re: Bonnet balance link
Another thread on this site specifies that the rivets should be 5/16” in diameter and should have a brass rivet on either side of the hinge.
Alan
N.J.
Alan
N.J.
#6 Re: Bonnet balance link
I think you mean a brass washer either side.
Shop for brass shim washers, as you will want them thin, like about .010"
peters3103
#7 Re: Bonnet balance link
Ok, thanks all for your input.
#8 Re: Bonnet balance link
I usually don't bother when we zinc plate them.
If you do decide to disassemble them be careful not to lose the brass washers.
peters3103
#9 Re: Bonnet balance link
Thanks Andrew. If it’s an option to have them plated without removing the rivets then I’ll do that.
#10 Re: Bonnet balance link
Look on balance I think it's easier.
If you sandblast them well first and make sure they they are straight so that no large bits get missed they should look ok.
You may get a little rust leaking out from the rivet heads but pulling them apart and putting them back together is a pita. Just my 50c worth.
peters3103
#11 Re: Bonnet balance link
