#1 brakes bleeding S1 4.2
Posted: Sun Jan 05, 2020 6:39 pm
by cooper66
Hello,
It is definitely a newbie question, nevertheless this is my first intervention on the braking system, and I cannot bleed the front calipers short summary :
-new master vac
-new master cylinder
-restored calipers (tested)
-new brake lines (tested with compressed air and no leaks)
I implemented by the Haynes the following brake pipes :
I respected the order and started by the rear calipers, with manual bleeding (one at the brake pedal and the second bleeding at the caliper). Result is ok brake pedal is hard => issue is for the front calipers, impossible the get fluid out of the bleeding nipples and even if nipples are opened the pedal stay hard.
Any idea ? I'm stuck here ...
#2 Re: brakes bleeding S1 4.2
Posted: Sun Jan 05, 2020 10:47 pm
1. Use a syringe to try to squirt fluid from the reservoir hose into the front circuit with the front caliper bleeder open.
Note that the front and rear systems are entirely separate and so make sure you are squirting the fluid in from the correct reservoir hose.
If this works, do both sides and then try your pedal again.
http://www.projectetype.com/index.php/t ... ringe.html
2. Sometimes with initial bleeding the shuttle in the tandem slave cylinder (L in your diagram) can get pushed too far forward and prevent fluid entering the front system. Try putting fluid under pressure into the caliper via the bleed nipple to see if you can move it back, then try 1 again.
3. Check that there is actually a hole in the booster for the fluid to come out. Seriously.
#3 Re: brakes bleeding S1 4.2
Posted: Sun Jan 12, 2020 4:02 pm
by Springer
Maybe a stupid question but since the front caliper has its own master cylinder. Are you sure you got the mechanical connection from the pedal box to the cylinders correct?
Can you actual see it is pressure on the master cylinder to the front calipers?
If it is and you can open bleeders on both sides and the pedal it still hard I would have looked at the master cylinder first.
#4 Re: brakes bleeding S1 4.2
Posted: Sun Mar 15, 2020 6:39 pm
by cooper66
Hello,
Thanks to your tutorial Andrew it works perfectly for bleeding the front. So now all the 4 calipers are bleeded the pedal is hard but when i start the engine the pedal stays hard !
I checked all the vaccum system, the pipes connections are correct according to the diagram in my first post.
Do you have any idea of the root cause ?
#5 Re: brakes bleeding S1 4.2
Posted: Wed Mar 18, 2020 9:00 pm
by cooper66
I'm thinking to a too long master cylinder rod, does it have sense ?
#6 Re: brakes bleeding S1 4.2
Posted: Wed Mar 18, 2020 9:10 pm
By this I assume you mean that the pedal effort is not made easier when the car is running?
If this is the case I would still suspect a problem with the vacuum assist on the brakes.
Double check you have the hoses correct. Check that the valve on the top of the vacuum reservoir is working correctly. Check that the reaction valve in the front of the pedal master cylinder is functioning correctly.
#7 Re: brakes bleeding S1 4.2
Posted: Fri Mar 20, 2020 11:38 am
by cooper66
hello Andrew,
I mean that after strating the engine the brakes stay blocked and the pedal is hard.
*) hoses connections checked and correct
*) How to check the valve on the top of the vaccum reservoir ? this is a one way valve right ?
*)reaction valve in the front of the pedal master cylinder => checked and functionnal
Could it be the the shuttle in the tandem slave cylinder which may be blocked in one specific position ?
thanks
#8 Re: brakes bleeding S1 4.2
Posted: Sun Mar 22, 2020 8:37 am
by cooper66
issue found, it was it was the adjustement of the pedal height which did not allow the master cylinder to open enough and allow the DOT4 to come back into the reservoir !
Bleeding has been done again and it's ok now !
Thanks for the different advices
#9 Re: brakes bleeding S1 4.2
Posted: Sun Mar 22, 2020 9:30 am
Good outcome.
