#1 Air intake trumpet
Posted: Wed Jan 08, 2020 8:46 am
by peters3103
Ok rivet counters, should this part be silver or hammertone. Can’t find anything in the Haddock bible apart from a pic which looks matt silver.
JCNA judging guide:
Is what they refer to as “BASE (TO CARBS)” the intake trumpet?
Cheers,
#2 Re: Air intake trumpet
Posted: Wed Jan 08, 2020 9:14 am
The new one I bought recently from SNGB was hammertone.
#3 Re: Air intake trumpet
Posted: Wed Jan 08, 2020 9:58 am
by peters3103
Thanks Andrew, mine is currently hammertone (that’s not mine pictured above btw) but I thought I’d repaint it while its off. I guess if the SNG supplied one comes hammertone that would be correct.
#4 Re: Air intake trumpet
Posted: Wed Jan 08, 2020 10:52 am
by Robbiee
No evidence of hammer finish on my 2 original ‘62 trumpets
I’ve repainted with smooth silver (slightly metallic) same as triangular Allie box
Robbie
#5 Re: Air intake trumpet
Posted: Wed Jan 08, 2020 9:42 pm
by 288gto
From the “Factory Fit Series 1 3.8” section on the forum....
#6 Re: Air intake trumpet
Posted: Wed Jan 08, 2020 11:05 pm
by peters3103
Well I’ve dropped the ball there, I should’ve referred to the Factory Fit first. Must remember that in future. It certainly appears, on the red car at least, that the plenum is hammertone and the trumpets are silver. That’s where I must’ve seen it previously.
#7 Re: Air intake trumpet
Posted: Thu Jan 09, 2020 6:48 am
by Robbiee
That sounds correct
Trumpets smooth silver and...
I just checked my plenums and they are both hammered finish...quite subtle silver though ..not that vey “speckled” finish that is sometimes seen
Hope that helps
Robbie
#8 Re: Air intake trumpet
Posted: Thu Jan 09, 2020 8:21 am
by peters3103
Cheers Robbie.
#9 Re: Air intake trumpet
Posted: Mon Jan 13, 2020 6:43 am
by ysmalkie
Would it not be the same silver as used on the headlamp scoops?
Tadek
#10 Re: Air intake trumpet
Posted: Mon Jan 13, 2020 8:16 am
by peters3103
I ended up using the Eastwood’s cad colour aerosol that I bought for my front suspension parts. I’m happy with it.
