Spark plug lead length for 3.8 needed (after March '62)
ysmalkie
Poland
#1 Spark plug lead length for 3.8 needed (after March '62)
Post by ysmalkie » Sun Feb 23, 2020 8:51 pm
Does anyone have measurements of the original spark plug lead lengths for the 3.8 engine (as specified below)?
Tadek
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
#2 Re: Spark plug lead length for 3.8 needed (after March '62)
Post by abowie » Sun Feb 23, 2020 9:30 pm
You're best off cutting them to length yourself.
Start with the longest lead first (#1). Then if you cut it too short you can still use it for the next longest etc etc.
If you are using the hard sheath I recommend enlarging the holes, and using silicone spray to facilitate inserting the leads.
ysmalkie
Poland
#3 Re: Spark plug lead length for 3.8 needed (after March '62)
Post by ysmalkie » Mon Feb 24, 2020 8:20 pm
At times like this my awareness of how fortunate I have been with my XK120 grows higher and higher..
I had everything down to spark cables original on a '53 car. Not to mention spare tyre, tubes, keys, etc, etc..
Tadek
Tadek
Jaguar XK120 OTS
#4 Re: Spark plug lead length for 3.8 needed (after March '62)
Post by abowie » Mon Feb 24, 2020 9:00 pm
Yes. There's nothing like starting with a complete running car.
My last restoration...
ysmalkie
Poland
#5 Re: Spark plug lead length for 3.8 needed (after March '62)
Post by ysmalkie » Tue Feb 25, 2020 9:15 am
Well, here is how original cables look on a XK120 from '53.
They are actually the same length as on the early 3.8 e-type.
Not a person here has original cables from later 3.8?.. :waiting:
Tadek
Tadek
Jaguar XK120 OTS
#6 Re: Spark plug lead length for 3.8 needed (after March '62)
Post by abowie » Tue Feb 25, 2020 8:12 pm
Tadek
It's pretty much the same engine. Copy those and you'll be spot on. If you use right angled spark plug caps you may need them slightly shorter.
#7 Re: Spark plug lead length for 3.8 needed (after March '62)
Post by chrisfell » Tue Feb 25, 2020 8:49 pm
Just a small point, but I once watched a concours nazi, (sorry, judge), criticise the routing of plug cables on an early E which were as shown in the photo of the XK above. On early Es, the cables were routed between the cam covers at the front of the head. Someone with access to a judging guide will correct me if this is wrong.
ysmalkie
Poland
#8 Re: Spark plug lead length for 3.8 needed (after March '62)
Post by ysmalkie » Fri Feb 28, 2020 8:30 am
Probably very right - they do have the same part numbers though as the later XK120ies...
Tadek
Tadek
Jaguar XK120 OTS
ysmalkie
Poland
#9 Re: Spark plug lead length for 3.8 needed (after March '62)
Post by ysmalkie » Mon Mar 02, 2020 10:05 pm
So, I think it could have changed thoughout the production:
Early car:
Later car:
and last version:
Tadek
Tadek
Jaguar XK120 OTS
