electric or wet oil pressure gauge
jeffbezz
Malta
#1 electric or wet oil pressure gauge
Post by jeffbezz » Sat Apr 18, 2020 8:06 pm
:helpsos: hi I have a 1962 jaguar etype with the 3.8 engine. Regarding its oil gauge, what was the factory fit , an electric gauge or wet gauge please. Thank you
#2 Re: electric or wet oil pressure gauge
Post by abowie » Sat Apr 18, 2020 8:54 pm
Electric.
Tbob
#3 Re: electric or wet oil pressure gauge
Post by Tbob » Sun Apr 19, 2020 2:47 am
I am interested in switching to a wet gauge. Any recommendations on a source for a good period correct gauge.
Bob t
LHD '69 OTS. (Former) basket case
#4 Re: electric or wet oil pressure gauge
Post by malcolm » Sun Apr 19, 2020 8:59 am
JUST fitted one, from SNG Barratt. Works brilliantly, I now know the real oil pressures. And it's still a "Smiths" clock, so matches the other guages perfectly. Only difference is that my original guage read to 60psi, this reads to 100.
Tbob
#5 Re: electric or wet oil pressure gauge
Post by Tbob » Sun Apr 19, 2020 12:22 pm
malcolm wrote: ↑
Got a part number handy?
Bob t
#6 Re: electric or wet oil pressure gauge
Post by Heuer » Sun Apr 19, 2020 2:40 pm
Tbob
#7 Re: electric or wet oil pressure gauge
Post by Tbob » Sun Apr 19, 2020 10:02 pm
Perfect. Thanks.
Bob t
64etype
#8 Re: electric or wet oil pressure gauge
Post by 64etype » Fri Apr 24, 2020 1:56 am
Lotus Europa....0-60 psi. Swap the bezel.
Eric
tim wood
#9 Re: electric or wet oil pressure gauge
Post by tim wood » Fri Apr 24, 2020 8:28 am
If you speak to caerbont who make the gauge that most of the usuals sell they can supply a wet gauge that reads to 60 psi and looks identical to the original electric item.
It’s not advertised on their web page.
#10 Re: electric or wet oil pressure gauge
Post by rswaffie » Fri Apr 24, 2020 8:38 am
I’ve not fitted one of these myself, but I think I read on this forum that the capillary tube will need to be coiled to a certain degree behind the dash. If you go for the steel braided option for the tube, there could be a risk of shorting if it touches any exposed connections. Might be safer to go for non-metal braided option if available.
MSM
#11 Re: electric or wet oil pressure gauge
Post by MSM » Fri Apr 24, 2020 9:14 am
64etype wrote: ↑
It's still an electric gauge, did you think it was a mechanical gauge?
Mike
#12 Re: electric or wet oil pressure gauge
Post by malcolm » Fri Apr 24, 2020 9:49 am
I'm ok with my mechanical guage reading to 100 rather than 60, because my oil pressure goes above 60 anyway, particularly when cold, so it's nice to know what it is getting to before the relief valve cuts in. I've kept the old electrical guage reading to 60 in case I ever sell and a purist wants originality
