flashing head lights ?
Polse7317
#1 flashing head lights ?
Post by Polse7317 » Fri Jun 12, 2020 1:53 pm
While i am fitting new wiring connections for the leds in the dash after a switch from +earth to - earth , i saw 2 wires non connected from the wiring loom of the steering column: a big clothed one blue/ yellow
and another clothed one "maroon" .
On the wiring diagram i see the B/Y going to "dipperswitch" ( what is the dipper switch and where is it in the dash? ) i think those wires are there for a flashing headlight function ( stand-by because my car is a american one ) but before i reconnect those and make a mistake .... i am sure someone here will solve my question :questionmarks:
PS: the "maroon" wire seems to be connected with a purple one from the dash because i have not any purple wire coming from the column loom.
wiring diagram.jpg (126.29 KiB) Viewed 2829 times
#2 Re: flashing head lights ?
Post by Heuer » Fri Jun 12, 2020 3:10 pm
Dipperswitch = high/low beam headlights. Long switch on speedo/tach dash panel.
Headlamp flasher is one the indicator - pull towards you to flash.
Stuart Exelby
#3 Re: flashing head lights ?
Post by Stuart Exelby » Fri Jun 12, 2020 5:34 pm
Dipper - dipped headlights. Full beam or dipped beam. :bigrin:
1967 Series 1 OTS
