#1 Should dashboard indicator lights flash
Posted: Fri Aug 21, 2020 7:44 pm
by 265bhp
Hi all
Am currently going through testing the loom and have an issue with the indicators
I have checked and checked and am pretty sure I have connected all the wires correctly on the indicator stalk switch...but
With standard bulb/lamps I get a flashing for the external body mounted indicators..but just a constant illuminated dash light behind the green triangles
With LED’s and the correct flasher unit (all from Better Lighting) I get only a constant illumination from the body indicator units and no lighting of the green triangles at all
First question please is whether the triangles should flash or not
Many thanks
Jonathan
#2 Re: Should dashboard indicator lights flash
Posted: Fri Aug 21, 2020 7:56 pm
by rswaffie
For both bulb types, the green dash lights should flash.
The wiring to the led flasher relay unit may be different to a non led unit, particularly the earth if you are on +ve earth. I had the similar issue and Gil provided the following info “ On your installation, please reinstall my relay and reverse the "+" and the "L" as your car is positive earth.“
I also used bettercarlighting for my leds, and I needed diode bridges fitted at the rear body indicators to prevent issues with other lighting circuits.
#3 Re: Should dashboard indicator lights flash
Posted: Fri Aug 21, 2020 10:15 pm
by 265bhp
Hi Richard
I had thought as much...I wonder what is wrong then as even with standard bulbs I have no flashing at the dash triangles...?
As for the LED set up...I have reversed the connectors on the flasher unit as I am running -VE earth...as per the advice from Gil..so that should be ok
It is indeed a puzzle
Best
Jonathan
#4 Re: Should dashboard indicator lights flash
Posted: Sat Aug 22, 2020 9:08 am
by MarekH
If you up my fee from last week's half a pastie up to a whole bacon sandwich plus tea, I'll come and sort it out.
#5 Re: Should dashboard indicator lights flash
Posted: Sat Aug 22, 2020 10:13 am
by rswaffie
Hi Jonathan
I would start by taking the led setup out of the equation and get the standard bulb/relay working.
If the direction indicators are flashing, but the dash warning are constant, that suggests either a wiring issue from the indicator flasher relay to the warning bulbs or more likely, an earthing issue at the indicator stalk end. The wiring diagram is pretty clear as to the config from the relay to the warning bulbs and back to the indicator stalk, so if all your connections are in line with the diagram, then my money is on an earthing issue at the stalk.
#6 Re: Should dashboard indicator lights flash
Posted: Sat Aug 22, 2020 7:27 pm
by 265bhp
Hi Marek
You have a deal..!..
Hi Richard
I think you are possibly right..the earthing is done via the fixing bolts which is suspect..I have tried extra earths to no available..but I am sensible enough to admit electrics are not my forte....
#7 Re: Should dashboard indicator lights flash
Posted: Sat Aug 22, 2020 7:54 pm
by rswaffie
Mine neither, though I’ve learnt plenty during my restoration. The electrics, whilst ostensibly the most straightforward part of the process (all new looms, lots of diagrams on the forum and the Coventry book) turned out to be the most frustrating part! Nine times out of ten the electrical problems I had were down to a bad earth somewhere. Maybe once or twice I didn’t read the diag correctly!!
#8 Re: Should dashboard indicator lights flash
Posted: Mon Aug 31, 2020 9:10 pm
by 265bhp
rswaffie wrote: ↑Fri Aug 21, 2020 7:56 pm
Hi Richard
Just to report the indicators are now working...but in order to get LED dash indicators I needed the same diodes as you had to use....and in order to get LED front and rear indicators Gil also suppliers me with a pair of Load Resistors
For anyone reading this thinking of doing LED it may seem a bit contrived, as the Load Resistors were the only way to simulate the load of a regular incandescent lamp...but for me the benefit was brighter lights ultimately during regular operation....and the resistors are over designed so as to not run hot in operation
All the best
Jonathan
#9 Re: Should dashboard indicator lights flash
Posted: Mon Aug 31, 2020 9:34 pm
by rswaffie
Glad you got it sorted out.
You are right, changing to LED bulbs can be a bit of a faff as we have both found out, it’s not just a case of replacing one for the other. However, the benefits in terms of brighter lights (stop lights much better) and less draw seem to be worth it in the end. I particularly like their blue dash/instrument bulbs - I can actually see my dials now!
