Hi, don't know if this should be here or in S2 bit.
I am taking on a S1.5 FHC LHD to RHD conversion for covid therapy. Must be mad !
Just trying to clarify something.
Washer bottle is on the RHD bulkhead and cannot stop there when the new pedals go in. Where do you put it ? Do you swap it over with the radiator expansion tank from the LHD bulkhead side ?
Or .. can it go on the RHD engine frame rail above the fuel filter/chassis plate area ? I can only find pictures of this on 2+2 cars - or could it work for non 2+2 ?
Many thanks
Keith
S1.5 question
#1 S1.5 question
Present - Series 1.5 FHC 1968, Opalescent Silver Grey - Illinois car.
2009 - Series 1 FHC 3.8 1963, Opalescent Maroon - Dutch ex USA car used in France.
1995 - Series 1 FHC 3.8 1962, Carmen red - from E Type Centre as was.
#2 Re: S1.5 question
I placed mine on the LHS
The bulkhead has captive nuts in the correct place.
Radiator expansion tank goes on the Right, again fixing points are present.
All a bit tight with throttle linkage, pipes and cables.
