#1 Hydraulic reservoir fitment 1965 S1 4.2
Posted: Thu Jan 28, 2021 5:49 pm
by phoenix
Hi I am just trying to fit the hydraulic reservoirs onto the bulkhead and I can see two threaded holes but should all three be fitted there or should the clutch one be on the other side of the car . I am also fitting the reservac cylinder and I can see three threaded holes one at the top two below at the bulkhead .( this car has had a lot of repair work prior to me ) I can see the flat bit on the cylinder the allows fitment of the oil filter so it looks to be in the correct position
but only the one hole at the top .
#2 Re: Hydraulic reservoir fitment 1965 S1 4.2
Posted: Fri Jan 29, 2021 11:58 am
by tim wood
Front brakes and clutch on the right hand side adjacent to the throttle linkage.
Rear brakes on the left above the servo mounted on a bracket attached to the large blanking plate for left hand drive pedals.
