Water proofing
vipergts
#1 Water proofing
Post by vipergts » Fri Jan 29, 2021 8:03 pm
Is there any way of preventing water ingress on a Roadster?
Comes in through or around the doors. I end up with pooling along the sill.
I’ve fitted membranes with flaps etc and can’t seem to stop it.
Would dearly love to use the car more but rain stops play
S1 4.2 Roadster in Resale Red
#2 Re: Water proofing
Post by mgcjag » Fri Jan 29, 2021 8:17 pm
Do you have drain hole covers fitted to the bottom of the doors......without them water will come over the sill seal....Steve
vipergts
#3 Re: Water proofing
Post by vipergts » Fri Jan 29, 2021 8:32 pm
Yes indeed. Everything present and correct.
#4 Re: Water proofing
Post by MarekH » Sun Jan 31, 2021 7:14 pm
If you have wax in the bottom of the doors, then it ought not to come out at the various bolts on the bottom of the door, but rather through the (unblocked) drain holes instead.
288gto
Russia
#5 Re: Water proofing
Post by 288gto » Sun Jan 31, 2021 7:18 pm
Have you thought about using a smoke generator and see where the smoke is escaping from? I'm also assuming you have the notches in the sill rubbers and they line up with the drain channels? Are the channels clear? My original doors also had plastic trim grommet/seals just in the bottom trim clip holes. If you haven't got any, maybe some non setting mastic. Have you removed the door card and is there evidence of staining on the back of it.
I also found 3M paint protection film was really good as a membrane because you can warm it up and mold it into all the recesses.
Just a few suggestions,
#6 Re: Water proofing
Post by Heuer » Mon Feb 01, 2021 10:47 am
From the Forum KB:
Jaguar Service Dept Water leak prevention:https://www.dropbox.com/s/cb5usq2cufpfq ... s.pdf?dl=1
MarkRado
Austria
#7 Re: Water proofing
Post by MarkRado » Tue Feb 02, 2021 6:03 am
Water tends to find unbelieveable ways esp on an OTS Etype;
I found the a-post seal to be crucial, in your case start checking contact of this seal
- where it meets the hood (first ingress when driving in heavy rain)
- around the dogleg between door and body (first ingress when washing the car)
I got tired buying, modifying and trying apost seals from different suppliers, and now live with some water on the sills and a towel as companion on longer trips; I have the ambition to get it right, though.
1963 OTS 880436
vipergts
#8 Re: Water proofing
Post by vipergts » Tue Feb 02, 2021 8:34 pm
288gto wrote: ↑
Some thoughts there. PPF is a good idea. Like that.
Also the sealing of the bottom trim studs. Like that
vipergts
#9 Re: Water proofing
Post by vipergts » Tue Feb 02, 2021 8:36 pm
MarkRado wrote: ↑
Yes I’ve looked carefully here especially in the sort of water capture tray on top of the door where water can escape between the pop riveted metal. All sealed.
