#1 Alternator adjustment bracket
Posted: Thu Feb 11, 2021 11:08 am
by phoenix
Hi can anyone tell me which bolts the bracket attaches to on the water pump. The 2 top ones look correct but they are to short .so 4.2
#2 Re: Alternator adjustment bracket
Posted: Thu Feb 11, 2021 1:24 pm
by MdR
Hi, I have got a document based on a series II, but I think it's the same for a series I;
Dia x Lenght Thread
I&J: 5/16" x 3 1/4" 24 x UNF
K&L: 5/16" x 1 1/2" 18 x UNC
M: 5/16" x 2 5/8" 24 x UNF
N: 5/16" x 3 1/8" 24 x UNF
O: 5/16" x 2 3/4" 24 x UNF
P: 5/16" x 2 5/8" 24 x UNF
Q: 5/16" x 1 1/8" 18 x UNC
#3 Re: Alternator adjustment bracket
Posted: Sat Feb 13, 2021 11:45 pm
by JPowers
I've just removed the two bolts you were asking about as part of replacing my water pump. They are 1 7/8" long 5/16" UNC. Incidentally, there are 2 spacers that go between the water pump and the bracket to ensure proper alignment with the adjuster arm of the alternator.
Cheers,
Jim
#4 Re: Alternator adjustment bracket
Posted: Sat Feb 13, 2021 11:47 pm
by JPowers
Sorry, forgot to add that yes, the bracket is attached to the top two bolts
Cheers,
Jim
#5 Re: Alternator adjustment bracket
Posted: Sun Feb 14, 2021 11:00 am
by phoenix
I have downloaded two photographs one showing it mounted on the top two bolts. The other mounted lower down on the right hand side making the adjuster more vertical . Unfortunately the top two studs ? are not long enough to use and the finish on the end of them suggests they are original. I am loath to try to remove these as I have had to try and remove a snapped water pump bolt lower down and I ended up even with heating and tapping with a hammer etc snapping it and having to drill and re tap it . So it is going to be mounted lower down. Bryan
