Hello everyone. The indicator switch on my '67 needs to be replaced with a new one.
I am embarrassed to say that I am not finding a logical way to open the shroud (cover assembly) right behind the steering wheel that covers it. I can see that is made of two parts, but there are no visible screws nor a slot to pry it open. I don't want to damage it, so I thought I'd ask here if anyone has a solution to this apparently silly problem. Thank you.
Indicator switch shroud
#2 Re: Indicator switch shroud
The part opposite the one with the level is just held by 2 flat springs.
Just pull this part and the screws to remove the other one will appear.
Mich
Mich
Michel
