#1 Wiring diagram
Posted: Fri Mar 05, 2021 9:16 am
by JimH
Hi where can I get a wiring diagram I can read?
My modern Haynes manual diagram is dreadful even when I try to blow it up on the printer the wiring colour abbreviations are mostly illegible
#2 Re: Wiring diagram
Posted: Fri Mar 05, 2021 9:18 am
Look in the knowledge base section we have them there...Steve
#3 Re: Wiring diagram
Posted: Fri Mar 05, 2021 11:20 am
by MSM
Jim
These books by Coventry Auto Components are very good..
https://coventryautocomponents.co.uk/st ... ype+wiring+
#4 Re: Wiring diagram
Posted: Fri Mar 05, 2021 11:47 am
by christopher storey
#5 Re: Wiring diagram
Posted: Fri Mar 05, 2021 4:22 pm
by ChrisC
Yep agreed - very useful and reasonably priced.
#6 Re: Wiring diagram
Posted: Fri Mar 05, 2021 5:32 pm
by Gfhug
Jim, I suggest that this should be added to your library:
As Heuer says in the knowledge base, technical information, everyone should have a copy with pages from the technical section being for ready reference printed off for use in the garage/workshop.
And another vote for the Coventry Auto Component books
#7 Re: Wiring diagram
Posted: Fri Mar 05, 2021 6:33 pm
by JimH
I have that book and have copied all the relevant drawings very handy when restoring various parts.
I have now printed off some Colour wiring diagrams happy days
#8 Re: Wiring diagram
Posted: Fri Mar 05, 2021 6:35 pm
by JimH
Must admit I did strip this car when I was 15 Iām 51 now and can mostly remember where stuff goes
#9 Re: Wiring diagram
Posted: Fri Mar 05, 2021 7:56 pm
by Turnip
JimH wrote: āFri Mar 05, 2021 9:16 am
I re-drew the Haynes one ("from chassis numbers IE.500001") in Visio and saved it as a PDF. That way it prints nicely and you can zoom in without losing clarity. I did amend the layout to make it more readable, and had to leave a few un-necessary "extras" that didn't relate to my 1965 model. The missing areas are listed in the notes.
With a bit of luck it is still here:
#10 Re: Wiring diagram
Posted: Fri Mar 05, 2021 8:34 pm
by JimH
Cheers saved it dammed printers just run out of ink
#11 Re: Wiring diagram
Posted: Thu Mar 11, 2021 4:49 pm
by ChrisC
I had a similar custom made wiring diagram a few years ago and had it professionally printed as an A1 size poster (which was pretty cheap) which I stuck to the wall for easy viewing. Thats the advantage of PDFs they can be printed quite large
#12 Re: Wiring diagram
Posted: Thu Mar 11, 2021 5:23 pm
by Mark Gordon
I bought one of these and I have to say that it's fantastic! The first page is the overall schematic which is about the same as what is in the knowledge base. but then, each of the systems has its own page devoted to an enlarged view of what goes where and it even has a page with the instrument clusters showing where the connections of each wire go on the back of the instruments. It is by far the clearest, most easy to read and interpret set of wiring diagrams that I've seen. Well worth $20.
https://mossmotors.com/jaguar-e-type/bo ... als-e-type
