S1 Tachometer removal
Nick
#1 S1 Tachometer removal
Post by Nick » Sat Aug 14, 2010 9:58 pm
Any tips on the easiest way to remove the tacho ?
a) I've followed the service manual steps for removing the facia panel as far as slackening off the 3 screws and 2 nuts, but the panel is still held tight.
b) I also read on Jag-lovers about removing the top of the dash & getting to the tacho from the top. I've undone the nuts on the 2 captive screws in the fuse compartment, and the A pillar chrome pieces, but the dash top is also holding on fast. Perhaps the windscreen rubber or the air vents are holding it in place.
c) Alternatively I'm wondering if my wife's small hands can reach the tacho clamp screws from below through the jungle of wires & cables.
Any tips on a) b) or c) ?
Thanks,
Nick
Post by christopher storey » Sun Aug 15, 2010 4:33 am
Nick : at the outer ends of the fascia top there are two studs and nuts ( one at each end) similar to the ones in the fuse compartment . A 5/16 AF socket - I think - is needed . You should then be able to lift the fascia top off, although sometimes a bit of judicious bending is needed
It can be done from below , but is very difficult indeed
Post by Heuer » Sun Aug 15, 2010 10:00 am
I have removed mine several times (Dave Rawl's conversion, EL lighting) from beneath. Remove the under dash cover and you can reach up and slacken one of the knurled knobs. This allows you sufficient slack to rotate the tach to bring the other knurled knob into reach. With both off you can remove the special clamps. Main points to remember are disconnect the battery and remove the bulb holders/wires going to the tach before starting. Refitting is the reverse.
Nick
Post by Nick » Tue Aug 17, 2010 7:08 am
Dave/Chris,
Thanks for your comments. I got in from the bottom. I was thinking I would need to get both a finger and thumb on the knurled clamps but luckily I could unscrew them just from pressure on the side of a finger.
Getting the tacho back in & clamped up might be harder than getting it out, but cross that bridge etc.
Nick L.
38E
Post by 38E » Wed Aug 18, 2010 3:04 am
I just had my tach out from the underneath too. Just be careful you don't do what I did putting it back. Somehow, whilst rotating it to reach the other knurled nut, I managed to strain the choke indicator lamp.
This lamp is held together solely by the threaded red lens which shattered. It cost me $40 to get another shipped and a week off the road for the car because you can't install the choke light without removing either the tach or the dash top.
Clive, 1962 Coupe 860320
(sold)
