Can someone tell me where these spacers should go. On a series 1 2+2.
Spacer location
#1 Spacer location
- Attachments
- 2AE68443-8D83-42FA-8E6B-6BC8E66DAE7F.jpeg (28.32 KiB) Viewed 2238 times
67 series 1 2+2 ,68 MG midget 1st car,70 VW Dormobile type 2,3 BMW Isettas,2 Messerschmidts,
1 Heinkel Ireland,Zundapp Janus,Goggomobil Royal,Goggomobil Coupe & 7 Motorbikes
#2 Re: Spacer location
First three could be distance pieces to hold washer bottle away from bulkhead BD18957/1
Second three could be distance pieces on bolt securing cowl to radiator (you only need two) C15712
Third could be distance pieces under forward end of radiator tie bars BD25765
Fourth could be eccentric sleeve on accelerator fulcrum lever C23915
Second and third could be the other way around!
S1 OTS OSB; S1 FHC ODB
#3 Re: Spacer location
Could the large ones be from underneath the rear end of the front seat runners?
'68 Series 1.25 2+2
'68 Series 1.25 2+2
#4 Re: Spacer location
On a 3.8 yes but the later 4.2 seats did not use them
#5 Re: Spacer location
As it’s a 2+2 I understood they were for 2nd row foot clearance. Every little helps! I did away with mine as I preferred the extra headroom in the front.
'68 Series 1.25 2+2
'68 Series 1.25 2+2
#6 Re: Spacer location
Cheers I will investigate further tomorrow
#7 Re: Spacer location
I can’t say for sure but the bulkhead stand-off idea sounds likely for three. The radiator cowl sounds likely too but I thought under the mushroom front seat bobbins had spacers too. If it’s a LHD car there were spacers in the bottle shield to save crushing the asbestos.
The only thing I can say with 100% certainty is there’s no d in Messerschmitt, but you’re the microcar expert, not me.
#8 Re: Spacer location
It may not be related, but there are two “distance pieces”, part number C 24424, between the Alternator Bracket and Water Pump. They look a bit like the two as the third set.
As seen on my spare engine :-
Dave Rose
1967 Series 1 4.2 FHC
