Problem with pictures and Avatars
#1 Problem with pictures and Avatars
I am having problems getting decent sized picture in the text or to update my Avatar. Any clues
Tony (E typed)
Tony
Tony
looking at your image link it says
"http//i924.photobucket.com/albums/ad81/jagtony_photo/Etypereduced.jpg"
which implies that the photo on photobucket is being reduced and not presented here in its original size...
No offense intended but are you following the instructions on the welcome part of this forum? i followed them earlier today and it worked fine...
If you did follow the instructions then sorry you need someone with more knowledge than i have...
1964 FHC 4.2
It just occurred to me - perhaps you copied the script in the "image thumb" field by mistake. That would cause this problem as it creates a much smaller "thumbnail" picture on this forum.
You need the link in the "image" field not "imagethumb"
1964 FHC 4.2
Chris,
When I try to load the original size picture it state the image is to big so I have reduced it beforehand to 200 pixels.
I am probable doing it wrong so shall try again.
Tony
Tony
Tony (E typed)
Tony
Tony
Just testing image sizes. Getting bigger. Now I just have to work out my avatar?
Tony (E typed)
Tony
Tony
I seem to have done it. Things are looking up
Tony (E typed)
Tony
Tony
Yes , it is a bit misty. but I have the basic idea. I will change it for somthing a bit clearer.
Tony (E typed)
Tony
Tony
This one is a bit better
Tony (E typed)
Tony
Tony
