#1 Dunlop caliper bleed valve
Posted: Sat Jun 26, 2021 7:13 pm
Hi All....Dunlop caliper bleed valve has a ball bearing seal.......can you/have you ueed a standard taper seal bleed nipple. ..or an alternative to the ball.....thanks....Steve
#2 Re: Dunlop caliper bleed valve
Posted: Sat Jun 26, 2021 9:05 pm
It should work, and I have used both types interchangeably on OBCs.
The BB seals in a ring around the tapered hole at the bottom of the threads. A tapered bleeder should work as long as its taper is more acute than that of the hole.
Easy enough to test it; tighten it up and push the brakes and see if it leaks.
#3 Re: Dunlop caliper bleed valve
Posted: Sat Jun 26, 2021 10:30 pm
by Series1 Stu
OBC's?
#4 Re: Dunlop caliper bleed valve
Posted: Sun Jun 27, 2021 10:24 am
Old British Cars.
#5 Re: Dunlop caliper bleed valve
Posted: Sun Jun 27, 2021 10:48 am
by Series1 Stu
:seeingstars:
:thankyouyellow:
