#1 Moss box synchromesh
Posted: Thu Jul 15, 2021 3:29 pm
There have been many posts/comments about poor synchromesh in Moss boxes.
During the lifelong restoration of my '64 3.8 fhc I stripped the Moss box to ascertain it's condition.
Having driven it initially many years ago there was little or no synchro action.
The internals were in remarkably good condition, with still well defines groves on the synchro cones, the only ware evident was on the lay shaft just starting to break through the hardening. The shaft was replaced together with new needle rollers.
Something I've never seen referred to in any posts is the synchro throw over detent pressure. According to the workshop manual the throw over pressure should be 62lb. I measured mine e few times by simply pressing on a bathroom scale till throw over occurred, mine were both only around 42lb. According to the manual this can be adjusted by placing spacers below the detent springs. I inserted small 1mm thick washers below the springs & re-assembled. This was sufficient to restore throw over pressure to 62lb.
I've only recently (almost) completed restoration and only driven around the block a few times (because it's not road legal yet) but already there is a vast improvement in synchro action compared to what I remember it being before.
Will update once I've got it legally on the Road.
