Vibrations with newly balaced wheels
pmansson
Sweden
#1 Vibrations with newly balaced wheels
Post by pmansson » Wed Sep 29, 2010 6:33 pm
My 420 G is very smooth up until about 50MPH.
Then I get small but very noticeable vibrations. Small in that it?s not the slow but heavy vibrations that would hint at the prop shaft for example.
New Michelin XWX tyres.
If I look through the rear view mirror, the white roadmarkings become very blurred. If I hold 2 fingers on it, nice and firm, I can see clearly though the mirror
What shall I check next.....?
Nick
Post by Nick » Thu Sep 30, 2010 12:14 pm
Were the new tyres balanced correctly ? If there was no vibration before they were fitted that seems to be the obvious cause.
Are they bolt-on wheels or splined with spinners ? If splined the balancing machine should ideally have used a splined adaptor to correctly centre the wheel.
Post by Heuer » Thu Sep 30, 2010 12:27 pm
Try swapping the wheels front to rear and see if it persists. If the fronts are out of balance the steering wheel will shimmy. You can drive through wheel imbalance so the shaking should stop as you go faster.
First port of call should be back to the tyre fitters and get them to re-check the balance. As Nick says, splined wheels need to balanced on a special adapter which most garages do not have. Longstone tyres only do static balancing on these types of wheel. You can do it yourself with one of these: http://tinyurl.com/3x76rsq
pmansson
Sweden
#4 Balanced the front wheels on the car
Post by pmansson » Sat Oct 02, 2010 6:13 pm
I found a tyreshop where the elder Italian owner/manager has the equipment for balancing the front wheels when mounted on the car.
This did it!
(pretty hairy when he spins them up to over 100 MPH....
NB he first balanced all 4 wheels on the traditional machine, and found that they were not very good at all. Too heavy weights, and a several in the wrong place. I must tell the nice owner of the first place that his machine needs to be calibrated.
Woolfi
Post by Woolfi » Tue Nov 23, 2010 6:02 pm
I I have a similar problem with my EV12. Wire wheels must be fitted to the machine with a OUTER konus, which is pressing to the outer side of the center. Like the wheels are fitted to the car.
Normal adaptors are pressing inside the center of a wheel. Often the mechanics in the wheel-balancing companies are using the wrong adaptor, because they don't know or don't have the correct adaptor.
Kind regards Wolfgang Gatza
Please excuse my poor english.
Post by 1954Etype » Tue Nov 23, 2010 7:15 pm
Woolfi wrote:I I have a similar problem with my EV12. Wire wheels must be fitted to the machine with a OUTER konus, which is pressing to the outer side of the center. Like the wheels are fitted to the car.
Wolfgang, your english is much, much better than my German!
Post by PeterCrespin » Wed Nov 24, 2010 10:44 pm
1954Etype wrote: Wolfgang, your english is much, much better than my German!
Wolfgang's English is better than your English Angus :P !
JEP41
Post by JEP41 » Wed Nov 24, 2010 11:19 pm
Hi All,
I purchased from a garage closing down sale several years ago a wheel balancing machine that balances on the car. It works perfectly especially on the fronts but with a power lock at the rear I move the rears to the front to balance them. My machine is I think Australian made by a company called Redline, its quite an old machine now but has seem a lot of service before I bought it judging by the knocks and scrapes it has picked up, but now it is in semi retirement looking after just the family cars. Oh and it balances perfectly 8)
Kind Regards John
