#1 "Long Skirt" Nylon insert nuts source
Posted: Wed Sep 22, 2021 11:07 pm
by pgh64
Anybody have a verifiable source for these C.8667 "Long Skirt" 5/16"-24 3/4"H nylon insert lock nuts? I've tried getting them from sources on both sides of the pond with no luck. They're either not available at all, too short or the wrong thread. I tried Namrick UK and British Fasteners USA, nuts from the former came in too short and they were N/A at the latter. These are used all over the front subframe and elsewhere.
TIA!
#2 Re: "Long Skirt" Nylon insert nuts source
Posted: Thu Sep 23, 2021 7:46 am
by rswaffie
When I restored by 3.8, I purchased the complete fastener set from Monocoque Metalwork. Drop Chuck an email, he may be able to help.
#3 Re: "Long Skirt" Nylon insert nuts source
Posted: Thu Sep 23, 2021 8:07 am
C8667 nuts come in a range...with a / indicating the type. ...so c8667/1...c8667/7 etc.....most suppliers have locknuts in half...standard...thick sizes..have you asked for thick nut.....Westfield fasteners have them at 0.344in thick.......Steve
#4 Re: "Long Skirt" Nylon insert nuts source
Posted: Thu Sep 23, 2021 8:48 am
60 years has passed, and sadly the current vendors will sell you anything that will do the job.
Getting an identical fastener to what was originally used is often impossible.
#5 Re: "Long Skirt" Nylon insert nuts source
Posted: Thu Sep 23, 2021 3:32 pm
by pgh64
mgcjag wrote: ↑Thu Sep 23, 2021 8:07 am
I've tried ordering "thick", "heavy", "NU" and "P Type". All wrong. It's the height that seems to be the challenge. While the nut is a simple 5/16 UNF nylon insert, the OEM nuts Jaguar used are .7/16" tall. I'll try Westfield though, Cheers.
#6 Re: "Long Skirt" Nylon insert nuts source
Posted: Thu Sep 23, 2021 4:39 pm
Where exactly are these nuts...i cant recall seeing 0.75in 5/16 nuts anywhere on an E type. ....Steve
#7 Re: "Long Skirt" Nylon insert nuts source
Posted: Thu Sep 23, 2021 5:42 pm
I think there may be a misapprehension/misdescription here about these nuts . They are shown in the parts catalogue as 34 of C8667/2 self locking and 2 of C8667/3 self locking. These are 5/16 UNF and 3/8 UNF respectively and the 8667 denotes that they are all what Jaguar described as Tall Skirt . I am pretty sure that these are what are now described as Nyloc P type nuts, the T type being the short skirt which carry a C8737 part number in Jaguar parlance. I have never seen an E type with anything like 3/4 inch deep nuts
PS nor, when I think about it, have I ever seen disproportionately deep nylocs, which 3/4 inch depth on a nut of 1/2" diameter( which the 5/16 UNF are ) most certainly would be
#8 Re: "Long Skirt" Nylon insert nuts source
Posted: Thu Sep 23, 2021 7:00 pm
by pgh64
mgcjag wrote: ↑Thu Sep 23, 2021 4:39 pm
Front sub/picture frame
#9 Re: "Long Skirt" Nylon insert nuts source
Posted: Thu Sep 23, 2021 7:01 pm
Can you measure them....Steve
#10 Re: "Long Skirt" Nylon insert nuts source
Posted: Thu Sep 23, 2021 7:06 pm
by dxke38
Just measured the original nuts on my car at 7/16" in height.
#11 Re: "Long Skirt" Nylon insert nuts source
Posted: Thu Sep 23, 2021 7:09 pm
Well thats a bit shorter than 0.75in....
#12 Re: "Long Skirt" Nylon insert nuts source
Posted: Thu Sep 23, 2021 7:12 pm
by pgh64
mgcjag wrote: ↑Thu Sep 23, 2021 7:09 pm
Yes, my bad. They are 7/16" tall, not .750
#13 Re: "Long Skirt" Nylon insert nuts source
Posted: Thu Sep 23, 2021 7:26 pm
by pgh64
Jaguar tall skirt OEM on left, typical Nylon insert nut on right. Jag version is 7/16" tall
#14 Re: "Long Skirt" Nylon insert nuts source
Hi...whats your name...please try to put it with your car model in the signature area thanks.....i would have to search the same as you but at least we now have a dimension to work to.........iv only used those supplied by tne usuals and never noticed the difference but tben i never measured them and wasnt doing a concourse car......as mentioned in a post above try Monocoque.......Steve
#15 Re: "Long Skirt" Nylon insert nuts source
Posted: Thu Sep 23, 2021 8:05 pm
by pgh64
mgcjag wrote: ↑Thu Sep 23, 2021 7:26 pm
Got it. Thanks. Unfortunately Chuck doesn't have these, and most of the stuff he does have is all gold zinc Grade 8
#16 Re: "Long Skirt" Nylon insert nuts source
Posted: Thu Sep 23, 2021 8:08 pm
by steve3.8
The correct frame nylocs are taller than type P, also a thicker than standard washer is used .
The only place i have managed to source these nylocs from is Uryk at E Type Fabs - he will have a full frame fitting kit if you need bolts and shims too.
#17 Re: "Long Skirt" Nylon insert nuts source
Posted: Thu Sep 23, 2021 8:11 pm
by pgh64
steve3.8 wrote: ↑Thu Sep 23, 2021 8:08 pm
Great! I'm familiar with E Type Fabs. Thanks!
#18 Re: "Long Skirt" Nylon insert nuts source
Posted: Fri Sep 24, 2021 10:33 am
by Allrand
I boight a frame fitting kit from Martin Robey, that was years ago, don't know if they still supply it.
