Ha, welcome Andrew, to the line-up of losers.
This web page pretty much nails it.
http://www.projectetype.com/index.php/t ... -test.html
Re Geoff’s Caerbont chart, for Jaguar:
Pre V12 = 60 psi = C15474 use PTR1801-06
Early V12 = 80 psi = C31177 use PTR1811-10
Later V12 = 100 psi = C46272 use PTR1801-10 or PTR1001-10EC (the latter is more linear)
You have a 60 psi gauge however you can get satisfactory results with a different range sender, for example the above recommends a 100 psi sender for an 80 psi gauge. If you are desperate, it is possible to tweek the two screws on the back of the gauge, you do need to dismantle to figure out the non-intuitiveness, but it does mean there are more options than the above. Tweek too far and the needle falls off its pivot, don’t despair, can be recovered ...
Note some of the Carebont senders are defined as having “euro winding”, these will cause yr gauge to display incorrectly. Basically there are two standards, the American marine standard uses zero .. full scale = 240 .. 33 ohms, the European marine std is zero .. full scale = 10 .. 180 ohms, i.e. euro is virtually inverse to the American std that Jaguar oil pressure gauges depend on.
https://fariabeede.com/site_manuals/IS0 ... %20rows%20
The trouble with trial and error is that each sender is the best part of $100 so experimenting can get expensive ...
The old Smith gauges are part of the problem, they are non-linear. Most modern senders have a quite linear response so the best you can achieve, with a new sender and an old Smiths gauge, can be with significant mid range inaccuracy. The local Caerbont agent tried to reduce this by printing up a different face for my gauge, but not good enough even after squishing the critical low pressure end of the scale too much for my liking ...
The last Caerbont PTR1811-10 that i purchased couldn’t detect any pressure below 25 psi. SNGB advised, “this is a known issue, here is your money back, you can keep the sender”. After unsuccessfully trialling all potential Caerbont senders I tried a VDO sender, this worked well enough. P/N 360-801, one of the very few 240-33ohm VDO senders:
Only problem, VDO senders are taller and, with the thread adapter (85 mm high, 45 mm dia.), couldn’t be installed where I want it to be, in the original hot spot down on the back left side of the V12 block. So if you want to give this sender a whirl, PM me an address and I’ll stick it in the mail.
My sol’n is to try latest tech, I’m using a Bosch 0261230340 pressure & temp sensor, via ecu I/O that will be calibrated so gauge displays exactly what the sensor detects or, channelling my inner zaphod Beeblebrox, whatever maintains my cool ...
I note Caerbont still manufacture the Jaguar style of Smiths 60 psi pressure gauge. I wonder how accurate a matching new gauge and sender would be? If the above doesn’t work, something I might look into. Or the mechanism from a cheap-as-chips ¼ sweep VDO gauge, retrofitted upsidedown into a smiths casing. It’s on my bucket list, accurate Jaguar electric oil pressure indication before I die ...
