#1 Lower Steering Column Removal
Posted: Mon Jan 24, 2022 4:58 pm
Howdy all. I'm refreshing the rubber seals on the steering column housing (the cast piece next to the brake/clutch cylinders that the lower steering column fits through). I'm curious if one can remove the lower steering column while the bonnet is on. My thought was to disconnect the lower steering column from the steering rack, and then push the column (gently) into the passenger compartment until it clears the frame members, and then take it out to the side. Anyone done this? Advice is greatly appreciated.
B.
B.
