P clip on vacuum tank to servo hose
#1 P clip on vacuum tank to servo hose
Dear all
Please could someone tell me where the Pclip on the hose that takes vacuum from the reservac tank to the Kelsey hayes servo is attached?
Robbie
Robbie
#2 Re: P clip on vacuum tank to servo hose
Never knew there was one.
Randall Botha
#3 Re: P clip on vacuum tank to servo hose
I’m pretty sure I’ve seen a photo somewhere of where it goes but I just can’t find it!
It’s on page 117 of the spare parts catalogue
One only on RHD car
One only on RHD car
#4 Re: P clip on vacuum tank to servo hose
#5 Re: P clip on vacuum tank to servo hose
Hi Robbiee
There was one on my LHD 3.8, but I think it was for routing of a different hose/cable - possibly the speedo?
Here it is during the restoration as I left it in situ when I converted to RHD.
#6 Re: P clip on vacuum tank to servo hose
#7 Re: P clip on vacuum tank to servo hose
Yes…there are 3 p clips on LHD but the orientation is different as the vacuum has to come from the tank on the opposite side of the car!
The RHD has only one P clip and I believe it helps hold the vacuum hose down against the left hand side of the master cylinder housing
I’m sure someone will have a picture!!
#8 Re: P clip on vacuum tank to servo hose
This picture is the clip for Speedometer cable (LHD) and keeps it angled correctly. I'd have to check on the P Clip location for the vacuum hoses.
1964 S1 3.8 OTS
1964 S1 3.8 OTS
#9 Re: P clip on vacuum tank to servo hose
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
Jaguar XK120 OTS
#10 Re: P clip on vacuum tank to servo hose
Thanks Tadek
That looks good for LHD
I reckon the RHD one goes as in my picture below
It seems to make the pipe curve correctly
Robbie
Robbie
#11 Re: P clip on vacuum tank to servo hose
You reminded me that I need a hose clip there!
Thanks! :-)
Thanks! :-)
Tadek
Jaguar XK120 OTS
Jaguar XK120 OTS
#12 Re: P clip on vacuum tank to servo hose
Hi Tadek
Is yours RHD?
Is yours RHD?
#13 Re: P clip on vacuum tank to servo hose
Same here, interesting detail, thanks.
Randall Botha
#14 Re: P clip on vacuum tank to servo hose
Only on this forum could we all find the position of single P clip “interesting”
I’m not even sure that I’ve got it under the correct nut!!
Does anyone think it should go on the one above instead??
Some nerdy chap out there must know
Robbie
Robbie
