#1 Sugar scoop fit and finish.
Posted: Sun Mar 20, 2022 2:47 pm
by TGN
How neat are the sugar scoops meant to fit under the headlamp glasses. Are they meant to hide the rear of the fixings for the chrome rim.
#2 Re: Sugar scoop fit and finish.
Posted: Sun Mar 20, 2022 5:03 pm
by DWW
Those screws are not right and are too long. One is not supposed to see any bodywork once the light glass seal and ring are finally fitted.
#3 Re: Sugar scoop fit and finish.
by Philk
The scoops should come up as close as possible to the chromes when viewed from above. There should be a protruding "flange" on the bodywork at the front of the scoops for them to rest on.
#4 Re: Sugar scoop fit and finish.
Posted: Sun Mar 20, 2022 9:39 pm
by Series1 Stu
Those screws should be machine screws, not self tappers. They should be screwed into captive cage nuts in the flanges.
#5 Re: Sugar scoop fit and finish.
Posted: Mon Mar 21, 2022 7:24 am
by TGN
So the sugar scoop should be able to pass through the opening in the bonnet to meet the glass/chrome?
Mine looks significantly misaligned, is this a normal amount to shim to fit or could it be exacerbated by a badly assembled bonnet?
What does the protruding flange look like?
#6 Re: Sugar scoop fit and finish.
Posted: Mon Mar 21, 2022 10:10 am
by Allrand
The left front edge of your scoop in the bottom picture is resting on the protruding flange, which needs to be bent up a bit to raise the front of the scoop. The rest of the left edge is as close as you're going to get it. The right side looks a bit low, I think maybe those scoops are a bit small. No the scoop cannot be lifted up to touch the glass or chrome. Try placing the glass with the seal & chrome over the opening, it'll look a look a lot less noticeable.
#7 Re: Sugar scoop fit and finish.
Posted: Tue Mar 22, 2022 8:03 pm
by TGN
Randall that’s definitely not as good as it’ll get and putting it back together doesn’t hide anything hence I’ve got it in pieces.
Here’s how the other side looked before I started on it as well
I do wish people would assemble everything before they rush to paint.
#8 Re: Sugar scoop fit and finish.
Posted: Wed Mar 23, 2022 8:50 am
by Allrand
That trim seems to be somewhat larger than it should be or too narrow, I wouldn't have expected to see so much bodywork visible.
#9 Re: Sugar scoop fit and finish.
Posted: Wed Mar 23, 2022 8:33 pm
by eddiecross
If it helps...Maybe pull the scoops and adjust to get them as close as possible to the body as a 1st step.
When I converted my S1.25 to scoops I had to adjust from scratch and just used extended bolts for the scoops where they attach to the headlight panel.
Bottom one with a nut threaded on + washer to act as a spacer to push the scoop as far up as possible at the front.
Then adjust left and right using nuts on the left and right threads from the back of the headlight panel.
I had no lip at the front for them to rest on but still worked pretty well.
#10 Re: Sugar scoop fit and finish.
Posted: Wed Mar 23, 2022 9:32 pm
by TGN
Thanks Eddie I’d read your thread on the conversion
After a little fettling I’ve slightly improved the aesthetics of the front end.
#11 Re: Sugar scoop fit and finish.
Posted: Wed Mar 23, 2022 9:38 pm
by DWW
Looks quite acceptable :bigrin:
#12 Re: Sugar scoop fit and finish.
Posted: Thu Mar 24, 2022 6:05 pm
by eddiecross
Looks great to me. Especially as your using glass not plexi
Eddie
