Accessory light bulb cross-reference
mtnjag
#1 Accessory light bulb cross-reference
Post by mtnjag » Mon Apr 04, 2022 7:57 pm
Does anyone have a cross reference chart from the Lucas PN shown in the manual to the modern equivalent. Looking for numbers used in the US or that I can cross to the US equivalent.
My car has a mix of bulbs for taillights-turn/brake,front running and turn, license plate, interior, etc. Some of the lamps in the fixtures are no longer legible so I don't know what has been used or the wattage.
I'd like to use the correct wattage and although form/fit may be right I either don't know the wattage of originals are or the new ones I have seen are wrong, typically too high.
Lacking a good cross, I have an early S1 OTS with stock lighting and info on the bulbs that are working well for others would be helpful.
Layne
Car #876005, 62 OTS
mtnjag
#2 Re: Accessory light bulb cross-reference
Post by mtnjag » Tue Apr 05, 2022 2:30 pm
This "Miniature Lamp Part # Interchange" was kindly supplied by David Langley on the Jag Lovers site.
Scroll through first couple pages for the Lucas numbers.
MiniaturePartNo_interchange.pdf
(192.5 KiB) Downloaded 174 times
Layne
Car #876005, 62 OTS
