Exhaust hooked safety bracket
ALAN COCHRANE
#1 Exhaust hooked safety bracket
Post by ALAN COCHRANE » Thu Jul 31, 2014 8:54 pm
Hi Everyone
I've bought one of these from SNG:-
https://www.dropbox.com/sc/ht2mbak82zua ... 97Tcvi0f3a
I've had a good look at the exhaust bracket and can't see how it will fit without drilling an additional hole between the two existing ones.
Can anyone show a photo of one fitted please?
Alan
Alan Cochrane
chrisvine
Post by chrisvine » Thu Jul 31, 2014 11:14 pm
Alan,
This is how I've connected up the exhaust 'catch' bracket. I think it should catch the welded brackets on the exhaust pipes if the rubber mount fails.
1969 S2 OTS, Elise S1
1954Etype
Post by 1954Etype » Fri Aug 01, 2014 7:48 am
Thats correct, it catches the tie plate bolting the 2 silencers together. Chris, now get u der your car and turn those brackets through 180deg, looks better and will give you a few more mill ground clearance. :wink:
Angus 67 FHC 1E33656
61 OTS 875047
ALAN COCHRANE
Post by ALAN COCHRANE » Fri Aug 01, 2014 8:35 am
Chris
Thanks for the photo-your bracket looks rather shinier than mine does. I thought that's how it fitted, but did you have to drill a third hole to accommodate the rubber mount's threaded stud coming through the back of the mounting plate? This is the bit that stumped me. Surely this hole should be drilled already? or am I having a senior moment(again)!
Can you also explain how you managed to make an image appear in your post rather than just a link as I've done? It looks a lot more impressive and is easier to see what is going on.
Alan
Alan Cochrane
Post by Heuer » Fri Aug 01, 2014 9:18 am
How to post pictures on the Forum: http://etypeuk.com/forum/viewtopic.php?t=1666
chrisvine
Post by chrisvine » Fri Aug 01, 2014 10:18 am
Alan,
My rubber mount didn't have a threaded stud (SNG part no JLM9542*):
http://www.sngbarratt.com/ProductDetail ... a9371b&l=7
Do you have a stud fitted instead of the single hole in the bracket? This connects to a 'U' shaped bracket (C18975) and the tail pipes then hang from this bracket (two outer bolts below):
Angus - in my defence, they hadn't been tightened at the time and so were hanging under gravity. All exhaust clamps have since been neatly tucked away due to my developing OCD :D
ALAN COCHRANE
Post by ALAN COCHRANE » Fri Aug 01, 2014 12:02 pm
Chris
Thanks for the extra photos. I think I see where I've got confused. The stud I mentioned connects the L-shaped strap from the underside of the boot to the crossbar that the rubber mount also attaches too. I 've looked at mine again and see there are packers inserted between the rubber mounting plate and the cross bar-presumably to allow for the threaded stud head.
The attached link will show you which one I've been going on about:-
https://www.dropbox.com/sc/c8mqv780dit2 ... D7ZwxOI4Sa
I wrongly assumed that this stud originated from the rubber itself, but this would negate the whole idea of the set-up-dohhhhh!
You will also notice that the rubber is in advanced state of detachment in readiness for the big split. So it's just as well I decided to look at this area of the car. A new mount is now on order.
David
Thanks for the info. I'm using Dropbox at the moment so may have to open a Photobucket account to achieve this.
Alan
Alan Cochrane
Philk
#8 Re: Exhaust hooked safety bracket
Post by Philk » Mon Jun 27, 2022 9:19 pm
Reading (as I do from time to time) the 3.8 Factory Fit section, I realised that my Stainless Steel exhaust does not have the "hooked safety bracket" (Part C19018) present to prevent the resonators from falling should the metallastic mount fail. Instead, the resonators (which look perfectly positioned from the rear of the car) have a stepped down tie plate (see photos below) as opposed to the standard tie plate which means the resonators are attached a couple of centimetres forward and down from where the originals would have mounted. This looks to be by design given the fabricated tie down plate.
My challenge is where (and how) to fit the safety bracket given where it hooks under is simply a smooth piece of metal as opposed to being under the edge of the tie plate. Has anyone else had this issue on their Stainless Steel exhaust systems and, if so, how have they attached the safety bracket?
1964 S1 3.8 OTS
caveman
#9 Re: Exhaust hooked safety bracket
Post by caveman » Tue Jun 28, 2022 8:07 pm
Here’s mine Phil,
Your rear silencers seem to be mounted a lot further back in comparison.
1965 S1 4.2 FHC (early)
:wavegreatbritain:
Maikel
#10 Re: Exhaust hooked safety bracket
Post by Maikel » Sun Jul 24, 2022 6:11 am
Here are some pics of an original,
no idea why the reproduction are always different.
