Hello,
For testing I would like to fit a replacement ignition coil. On the original item, the contact points are marked with "CW" and "SW". On the new one with "+" and "-". Which connection point of the old coil corresponds to that of the new one ? It is the 3.8 engine and unchanged positive ground.
Thank you for your help.
Ingnition coil connection points
#2 Re: Ingnition coil connection points
From memory, for positive earth cars, the wire from the ignition switch went to the "-" , which was the sw terminal on the old version.
#3 Re: Ingnition coil connection points
CB = contact breaker
SW = switch
In a positive earth car the negative wire goes to SW and the positive to CB which earths when the points close.
SW = switch
#4 Re: Ingnition coil connection points
Hello Richard, hello andrew,
For positive earth cars:
sw = "-" and
cb = "+"
Thank you
sw = "-" and
cb = "+"
Thank you
#5 Re: Ingnition coil connection points
It should be CB, not CW.
#6 Re: Ingnition coil connection points
Sorry,
you are right.
Best regards
you are right.
Best regards
#7 Re: Ingnition coil connection points
John an excellent guide to auto electrics is Rick Astley's book.
Publisher
Veloce Publishing Ltd
ISBN-13
9781845849481
Book Title
Classic British Car Electrical Systems: Your Guide to Understanding, Repairing and Improving the Electrical Components and Systems That Were Typical of British Cars from 1950 to 1980
Publisher
ISBN-13
9781845849481
Book Title
