Ingnition coil connection points
Desmo
#1 Ingnition coil connection points
Post by Desmo » Tue Aug 09, 2022 7:07 pm
Hello,
For testing I would like to fit a replacement ignition coil. On the original item, the contact points are marked with "CW" and "SW". On the new one with "+" and "-". Which connection point of the old coil corresponds to that of the new one ? It is the 3.8 engine and unchanged positive ground.
Thank you for your help.
#2 Re: Ingnition coil connection points
Post by rswaffie » Tue Aug 09, 2022 7:17 pm
From memory, for positive earth cars, the wire from the ignition switch went to the "-" , which was the sw terminal on the old version.
#3 Re: Ingnition coil connection points
Post by abowie » Wed Aug 10, 2022 12:04 am
CB = contact breaker
SW = switch
In a positive earth car the negative wire goes to SW and the positive to CB which earths when the points close.
Desmo
#4 Re: Ingnition coil connection points
Post by Desmo » Wed Aug 10, 2022 10:41 am
Hello Richard, hello andrew,
For positive earth cars:
sw = "-" and
cb = "+"
Thank you
#5 Re: Ingnition coil connection points
Post by abowie » Wed Aug 10, 2022 1:18 pm
sw = "-" and
cw = "+"
Thank you
It should be CB, not CW.
Desmo
#6 Re: Ingnition coil connection points
Post by Desmo » Wed Aug 10, 2022 2:22 pm
Sorry,
you are right.
Best regards
#7 Re: Ingnition coil connection points
Post by abowie » Thu Aug 11, 2022 12:22 am
John an excellent guide to auto electrics is Rick Astley's book.
Publisher
Veloce Publishing Ltd
ISBN-13
9781845849481
Book Title
Classic British Car Electrical Systems: Your Guide to Understanding, Repairing and Improving the Electrical Components and Systems That Were Typical of British Cars from 1950 to 1980
Desmo
#8 Re: Ingnition coil connection points
Post by Desmo » Thu Aug 11, 2022 7:59 pm
Thank you Andrew.
