#1 Rear Brake rebuild
Posted: Sat Aug 13, 2022 2:27 pm
Hi All, this Forum has been helpful to me over the past year so wanted to post something to help others. My series 1 OTS is a 1966 model and I found I had to start pumping the brakes. Fitted a new master cylinder as the fluid was full of air and couldn't get rid of it. Soon after, the rear callipers began to leak due to failed seals. I asked for several quotes to put the problem right and was astonished at the costs. One quote was touching £2.5k from one of the etype experts.
Problem is that everyone tells you that the rear subframne needs dropping to access the callipers and cylinders. I was quoted 14 hours just to drop the frame and put it back. That didn't even include the repair itself. I noticed that even amateurs seemed to be able to drop the rear subframe in a 2-3 hours. Considered doing it myself as I found a very useful video of the whole process on youtube.
In the end, I contacted a local company that does some repairs to classics and they did the whole job without removing the subframe. Simply put it on a lift and reached over. It's awkward but possible. I chose to fit new cylinders but could possibly have got away with new seals. Didn't want to risk it going wrong again so went for new at a cost of £450. Labour cost to fit the new cylinders was £500. So, shop around. E Type specialists seem to think we are all multi millionaires. The IRS rear subframe youtube video was posted by Fosseway Classic Car Workshop and it's brilliant. shows complete breakdown and rebuild if you fancy doing it yourself.
Good luck and I hope at some stage I will save someone some money. Ray Loud
