Hello,
Does anyone have a good photo of the profile of the original rubber seal for the early FHC ?
This would be a big help.
Rear Hatch Rubber Seal for the early FHC
#2 Re: Rear Hatch Rubber Seal for the early FHC
The best one if found was via Baines in the UK…came in a single length..not 2 pieces as from Wilkinsons
I don’t have a reference but if you search their web site under Jaguar E Type it shouldn’t be too difficult to find
All the best
Jonathan
All the best
Jonathan
#3 Re: Rear Hatch Rubber Seal for the early FHC
Check out "Similar Topics" at the bottom of this page - may be something there.
S1 OTS OSB; S1 FHC ODB
#4 Re: Rear Hatch Rubber Seal for the early FHC
Hi John
Found it for you
I have a feeling I had to buy 3m which left plenty left over but 2m was just too short
Single joint centred on the lower boot drain hole
Best
Jonathan
Found it for you
Best
Jonathan
