Help with horn
#1 Help with horn
Hi all, I need some help, my horn only works when the steering is centered and maybe 20 degrees each side of center. I am sure it is a ground issue but can’t seem to find that wire around the column. Anyone ever experienced this issue? Help would be appreciated.
#2 Re: Help with horn
Could be the sliding copper contact that sits against the inner column ..they can GT worn over time and loose contact
#3 Re: Help with horn
For just a moment I thought Flanders and Swann were going to come into this
#4 Re: Help with horn
#5 Re: Help with horn
Question is how do I get to it?
#6 Re: Help with horn
"Ill Wind"...their wonderful song about Flanders learning to play the horn, but finding it stolen was unable to give a performance. With apologies to Mozart.
I'm a huge fan of F&S; perhaps Christopher is too...
Jeremy
1967 S1 4.2 FHC
1967 S1 4.2 FHC
#7 Re: Help with horn
Danny.....Service manual....detailed steering column drawing.....your probably going to have to remove the column....Steve
#8 Re: Help with horn
This is what it looks like:
Suggest you dismantle the shaft and give everything a good clean. Basically the white ring clip sits over the shaft where the hole is. The small brass nipple fits into the hole, the spring goes on top and the brass collar holds everything in place. When the long thin inner brass rod is in place the nipple is in permanent contact with it regardless of rotation. The copper contact completes the circuit.
The original contacts were beryllium copper which is a good spring material. The new ones are regular copper, which is not. The BeCu will stay in contact, regular copper will relax to wherever it's held and not spring back. Hutsons sell ta repair kit if you need it. This is the repro copper contact to be wary of so try and reuse the original:
Start by checking the contact which you can do without dismantling the steering.
#9 Re: Help with horn
Thanks guys, in the mean time I consulted my manual before reading the las t post and went ahead to drop the top of the column and tapped the ground connecting box and contacts with a spanner and it all came back to life. if this approach doesn't last I will refer to the attached (thanks David) drawing/photos and delve deeper into it. I think the steering column was restored during the restoration so the ring hopefully was fresh.
#10 Re: Help with horn
Yes indeed ... and my favourite line from the Horn song is " Found my Horn.......Gorn"
here's a youtube link :
#11 Re: Help with horn
Love it!
