Boot boards for 3.8 fhc
#1 Boot boards for 3.8 fhc
Are the 2 boot boards the same for all 3.8 fhc or was there a change in design at some point? And did they change the boards for the 4.2? I want to make sure i get the right ones for a Feb64 3.8.
Darryl
#2 Re: Boot boards for 3.8 fhc
The part numbers changed for the S1 4.2 cars so the 3.8 boards are different.
S1 OTS OSB; S1 FHC ODB
#3 Re: Boot boards for 3.8 fhc
The parts catalogue doesn't show any changes throughout the 3.8 production run.
Presumably, you have the two piece rear mat?
'78 Land Rover Series 3 109
#4 Re: Boot boards for 3.8 fhc
Thanks chaps. I couldn’t see a difference in the 3.8 v 4.2 boards listed on SNGB, and the guy I’ll be using for trimming reckoned they were 4.2 boards. Do you have the correct part number for the 3.8 boards please? I assume black birch ply is the correct material?
Darryl
#5 Re: Boot boards for 3.8 fhc
Part numbers....3.8 parts catalogue...knowledge base section. ....Steve
#6 Re: Boot boards for 3.8 fhc
I did write them down so:-
BD21137 for spare wheel cover
BD19052 for fuel tank cover
#7 Re: Boot boards for 3.8 fhc
I seem to recall the widths are different for the 3.8 - I think Martin Robey list them by Stu's part numbers. Worth phoning to ensure you get the right ones. Or make your own - Measurements:
For comparison here are the S2 boards:
#8 Re: Boot boards for 3.8 fhc
Thanks all, a comprehensive response
Darryl
#9 Re: Boot boards for 3.8 fhc
I don't think the boot boards differ for the 1 piece or 2 piece mats. The 1 piece mat simply folds to the lhs to reveal the spare wheel board.
Randall Botha
'64 3.8 fhc & '51 Mk 7
