#1 Bodyshell acid dipping
Posted: Sun Dec 04, 2022 6:38 pm
by Maikel
Just for all those who are restoring a car and seeking information. My recent video shows acid dipping result.
I have started a new series of videos on my channel to follow complete nut and bolt restoration.
You might want to subscribe to my channel @JaguarEType and please post your comments on YouTube.
Many thanks
#2 Re: Bodyshell acid dipping
Posted: Thu Dec 08, 2022 11:32 am
by paydase
Thank you for the video.
Interesting to see the ways water can take to perform the inside out corrosion in the body.
One question: how does the specialised shop ensure that all traces of acid inside the hollow areas are fully removed/neutralised?
#3 Re: Bodyshell acid dipping
Posted: Mon Dec 12, 2022 1:05 pm
by Maikel
you newd to make sure tobhave at least 2 holes in eaxh cave.
The shell itself is mounted to a rotation frame which will aid to flush the acid out.
Finally it will all be cleaned with a high pressure water and protected with a kind of oil/grease layer which is what you see on the body.
Hope this helps
Maikel
#4 Re: Bodyshell acid dipping
Posted: Tue Dec 13, 2022 9:35 pm
by paydase
Yes, thank you.
So a lot of care (by a good workshop) has to be taken. Otherwise it could become a recipe for (hidden) bad surprises in the future...
