Hard Top Bracket
mxke
#1 Hard Top Bracket
Post by mxke » Sun Feb 12, 2023 12:49 am
Hi:
Did all OTS's have hard top brackets installed?
Mine did not have any, so I am trying to determine if they are missing or not required unless you have a hardtop?
Car # 878380
Thanks you,
Mike
Gerry
#2 Re: Hard Top Bracket
Post by Gerry » Sun Feb 12, 2023 2:17 am
Hi Mike my car has them 878269.
Regards Gerry Ontario Canada.
mxke
#3 Re: Hard Top Bracket
Post by mxke » Sun Feb 12, 2023 2:24 am
Thanks Gerry. I see our cars aren’t too far apart!
Mike
ralphr1780
#4 Re: Hard Top Bracket
Post by ralphr1780 » Sun Feb 12, 2023 11:06 am
mxke wrote: ↑
Mike
And mine is in the middle of both :bouncyyellow:
Ralph
'69 OTS + '62 OTS - Belgium
paydase
#5 Re: Hard Top Bracket
Post by paydase » Sun Feb 12, 2023 1:57 pm
The early OTS did not have brackets installed for attaching the hardtops.
I think I have read here that hardtops were produced later as a factory option (maybe in 1962?) and since then brackets were installed on the OTS body.
Certainly David (Heuer) could tell us whan was that...
Serge
1964 (3.8) FHC
1961 OTS
#6 Re: Hard Top Bracket
Post by Heuer » Sun Feb 12, 2023 2:52 pm
All bar the first 51 OTS's could be fitted with the hardtop. It did take Jaguar three goes to get a 'production' version sorted though!
paydase
#7 Re: Hard Top Bracket
Post by paydase » Sun Feb 12, 2023 3:19 pm
Thank you David.
So a "production version" was available from ca. March 1962, as numbers from XKEdata tell us.
Are pictures of the early pieces constituting kits A and B (brackets probably) available?
Serge
1964 (3.8) FHC
1961 OTS
#8 Re: Hard Top Bracket
Post by Heuer » Sun Feb 12, 2023 3:30 pm
None that I have been able to find. The fitting instructions would help but I don't have copies.
mxke
#9 Re: Hard Top Bracket
Post by mxke » Tue Feb 14, 2023 9:11 pm
Thank you all!
I will locate some brackets.
Mike
fats
#10 Re: Hard Top Bracket
Post by fats » Sat Feb 18, 2023 7:55 pm
Mike, I have an extra set of brackets if you want them. New from SNG.
I’m in Calgary.
Kent
1964 OTS
mxke
#11 Re: Hard Top Bracket
Post by mxke » Sat Feb 18, 2023 8:20 pm
Hi Kent
Just sent you a PM.
Mike
