Hard Top Bracket
#1 Hard Top Bracket
Hi:
Did all OTS's have hard top brackets installed?
Mine did not have any, so I am trying to determine if they are missing or not required unless you have a hardtop?
Car # 878380
Thanks you,
Mike
Car # 878380
Thanks you,
Mike
#2 Re: Hard Top Bracket
Hi Mike my car has them 878269.
Regards Gerry Ontario Canada.
#3 Re: Hard Top Bracket
Thanks Gerry. I see our cars aren’t too far apart!
Mike
Mike
ralphr1780
#4 Re: Hard Top Bracket
And mine is in the middle of both
Ralph
'69 OTS + '62 OTS - Belgium
#5 Re: Hard Top Bracket
The early OTS did not have brackets installed for attaching the hardtops.
I think I have read here that hardtops were produced later as a factory option (maybe in 1962?) and since then brackets were installed on the OTS body.
Certainly David (Heuer) could tell us whan was that...
Serge
1964 (3.8) FHC
1961 OTS
1964 (3.8) FHC
1961 OTS
#6 Re: Hard Top Bracket
All bar the first 51 OTS's could be fitted with the hardtop. It did take Jaguar three goes to get a 'production' version sorted though!
#7 Re: Hard Top Bracket
Thank you David.
So a "production version" was available from ca. March 1962, as numbers from XKEdata tell us.
Are pictures of the early pieces constituting kits A and B (brackets probably) available?
Serge
1964 (3.8) FHC
1961 OTS
1964 (3.8) FHC
1961 OTS
#8 Re: Hard Top Bracket
None that I have been able to find. The fitting instructions would help but I don't have copies.
#9 Re: Hard Top Bracket
Thank you all!
I will locate some brackets.
Mike
Mike
#10 Re: Hard Top Bracket
Mike, I have an extra set of brackets if you want them. New from SNG.
I’m in Calgary.
I’m in Calgary.
Kent
1964 OTS
1964 OTS
#11 Re: Hard Top Bracket
Hi Kent
Just sent you a PM.
Mike
Just sent you a PM.
Mike
