FACTORY FIT - Series 1 4.2
#41 Re: FACTORY FIT - Series 1 4.2
Post by Heuer » Mon Apr 29, 2019 12:33 pm
This is a 1964 one owner car with 26,000 miles on the clock and then for 40 years. Lots of interesting original detail and the only disappointment is the missing toolkit:
Some points worth noting:
Screws holding headlamp surrounds and side lights are slotted
Five way terminal for wiper motor is held in place with strapping - the 3.8 had a metal bracket
Early style heater box grill retainer
Position of latches with bonnet closed and locked
More photo here: https://lbilimited.com/offerings/1965-j ... -roadster/
S1 OTS OSB; S1 FHC ODB
#42 Re: FACTORY FIT - Series 1 4.2
Post by Heuer » Mon Apr 29, 2019 1:57 pm
Seen on the above car is this cloth label on the battery terminal lead.
We have seen it before on the underside of the Hardura of Steve's car:
Seat belts also labelled:
ysmalkie
Poland
#43 Re: FACTORY FIT - Series 1 4.2
Post by ysmalkie » Tue Apr 30, 2019 10:50 am
For those who want to have a copy: all photos in one zip file:
https://drive.google.com/open?id=19fdDy ... S7XmLuvO9x
Tadek
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
ralphr1780
#44 Re: FACTORY FIT - Series 1 4.2
Post by ralphr1780 » Tue Apr 30, 2019 12:05 pm
Nice pics.
But I really find it hard to believe this car covered only the stated low mileage, given various details.
Is it the car of the Beverly Hillibillies? :bigrin:
Ralph
'69 OTS + '62 OTS - Belgium
#45 Re: FACTORY FIT - Series 1 4.2
Post by Heuer » Sat Sep 14, 2019 11:16 am
1967 E-Type unrestored:
#46 Re: FACTORY FIT - Series 1 4.2
Post by Heuer » Sun Apr 26, 2020 2:10 pm
Tool Kit
All S1 4.2's left the Factory with a full tool kit which was wrapped in a clear plastic bag (see post #24). If a tool kit was subsequently ordered from the Spares Department it had the part number 11610 and was shipped in a brown bag. The Girling bleeder tin suggests this kit dates from late 1967:
#47 Re: FACTORY FIT - Series 1 4.2
Post by Heuer » Tue May 25, 2021 2:36 pm
Spark Plugs
The 4.2 cars were fitted with Champion N-5 sparking plugs by the Factory. These were changed from engine 7E10447 to N-11Y plugs due to complaints of plug fouling at low speed. The same problem occured with the 3.8 engines and the plugs were changed from N-5 to N-12Y in December 1962. Odd the Factory persevered with the N-5 -plugs on the 4.2's.
N = 14mm thread, 3/4" reach, 13/16" hex
5 = heat range, 11 is hotter
Y = Projected Cone Nose electrode
C = Copper core
