#1 Soundproofing questions
Posted: Fri Aug 04, 2023 7:36 am
Hi, time to do the first things to the painted car :-)
First picture. The two small square ones, where do they go? I would guess in the square indents above the rear axle. What's it actually for, the hole in the indent and the hole in the isolation pads indicate something that can be removed, but it can't?
Picture two, the parts at the rear of the table are clearly for footwells. But the three parts nearest the camera, where do they go? I had expected one square part that would fit the almost square area under the seat, picture three? The set is part# JE38F/SP, so should be ok?
