Correct length of the battery cables?
#1 Correct length of the battery cables?
Would anyone know what's the correct length of the battery cables on the 4.2 S1?
I am looking for the Battery +, Battery - and if possible the starter cable...
Tadek
Tadek
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
Jaguar XK120 OTS
david muir
#2 Re: Correct length of the battery cables?
Just buy very flexible welding cable which has a huge cross-section..........no current drop!
1964 3.8 FHC
#3 Re: Correct length of the battery cables?
But please, please, please, for the sanity of the next owner, buy a length of red cable for the positive terminal.
#4 Re: Correct length of the battery cables?
Or at least fit a red sleeve against the positive terminal.
Sorry, I can't help you with the cable lengths though.
#5 Re: Correct length of the battery cables?
Long enough to reach the terminals?
#6 Re: Correct length of the battery cables?
Thanks all for the advice! Does not get me close the exact dimensions, but the thought of having them long enough is very valid :-)
Tadek
Jaguar XK120 OTS
Jaguar XK120 OTS
#7 Re: Correct length of the battery cables?
As a matter of semantics, it is voltage drop not current drop
The current in a cable is the same at each end. The higher the current for a given cross sectional area the greater the voltage drop between the ends...cables have finite resistance. Thicker cables mean lower voltage drop and higher power availability at the load end...which is what you need for the starter. Unless your cable is a superconductor there will always be some voltage drop!
play on...
#8 Re: Correct length of the battery cables?
Hi Tadek, just measure the length from the solenoid along the Lh frame rail, across the ficture frame & back along the rh frame rail to the starter, allowing a little extra for slack. A PO routed mine around the rear of the engine to the starter. If you're not worried about orignality that's a good idea because it's quite a bit shorter.
Randall Botha
#9 Re: Correct length of the battery cables?
it will also depend on which way you intend to mount the battery. Originally the terminal posts were at the back, under the heater box, but that makes removal difficult so many owners mounted them the other way around. It also depends on which battery you intend to use as many makers no longer supply them with the correct FRV11/7A configuration - terminals at the back, +ve terminal on the left for 3.8 cars. Your chosen polarity will also effect your choice. Lots of information in the Factory Fit thread on the subject.
I have seen the braided earth cable with a 6" yellow sleeve although I can find no documented evidence it was original fit.
