I will have to change exhaust manifolds on my serie1.5 : broken link with exhaust pipe
doing that I would like to delete the cross over duct
reasons : aesthetics and more simplicity of engine compartment
is there any inconvenient to do that ?
my understanding is that if air is not pre heated in carburators I should have better enrichment and more engine power
Michel
cross over duct deletion on series 1.5
Topic author - Posts: 6
#2 Re: cross over duct deletion on series 1.5
Michel, can you confirm which carburettors you have, please? I’m guessing two Stromberg?
You may find good comments on jaglovers which is an American website and they will have more experience of doing something like this. Also they have comments about how to adjust Strombergs to give better performance as their cars had those carbs fitted unlike the UK or European cars.
#3 Re: cross over duct deletion on series 1.5
I’m certain that on some stromberg equipped cars (later ones) the crossover was indeed deleted and an aluminium cap fitted on the inlet manifold. The exhaust manifold could have the crossover unbolted although it doesn’t look great.
Tim
Tim
#4 Re: cross over duct deletion on series 1.5
#5 Re: cross over duct deletion on series 1.5
Yes two Stromberg carburettorsGfhug wrote: ↑Thu Nov 16, 2023 6:00 pmMichel, can you confirm which carburettors you have, please? I’m guessing two Stromberg?
#6 Re: cross over duct deletion on series 1.5
hello Tim
I know that later cars (series 2) did not keep crossover duct
in that case I would change also rear exhaust manifold not keeping current one who presents bolts to fit crossover duct
Michel
