#1 Clutch pipe/hose/bracket routing LHD
Posted: Tue Feb 27, 2024 2:32 pm
by No Quarter
I have the parts below and can make double flanged pipes. But can't find a picture of routing. Where exact are brackets attached, and picture of pipe routing would be great. Remember LHD.
#2 Re: Clutch pipe/hose/bracket routing LHD
Posted: Tue Feb 27, 2024 6:57 pm
by ysmalkie
Not the best photo, but should give you an idea:
- top L shaped bracket is mounted on the inner, lower frame setscrew
- the small bracket is mounted on one of the screws mounting the block to the gearbox bracket
BTW, they are both the same colour as the radiator brackets (blueish).
Tadek
#3 Re: Clutch pipe/hose/bracket routing LHD
Posted: Tue Feb 27, 2024 10:18 pm
by ysmalkie
In addition, the metal pipe routing:
Note the 2 clips.
Tadek
#4 Re: Clutch pipe/hose/bracket routing LHD
Posted: Wed Feb 28, 2024 5:52 am
by No Quarter
Perfect Tadek :bigrin:
