Clutch pipe/hose/bracket routing LHD
No Quarter
Denmark
#1 Clutch pipe/hose/bracket routing LHD
Post by No Quarter » Tue Feb 27, 2024 2:32 pm
I have the parts below and can make double flanged pipes. But can't find a picture of routing. Where exact are brackets attached, and picture of pipe routing would be great. Remember LHD.
Mikael
Author of "Tuning Made Easy"
ysmalkie
Poland
#2 Re: Clutch pipe/hose/bracket routing LHD
Post by ysmalkie » Tue Feb 27, 2024 6:57 pm
Not the best photo, but should give you an idea:
- top L shaped bracket is mounted on the inner, lower frame setscrew
- the small bracket is mounted on one of the screws mounting the block to the gearbox bracket
BTW, they are both the same colour as the radiator brackets (blueish).
Tadek
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
ysmalkie
Poland
#3 Re: Clutch pipe/hose/bracket routing LHD
Post by ysmalkie » Tue Feb 27, 2024 10:18 pm
In addition, the metal pipe routing:
Note the 2 clips.
Tadek
Tadek
Jaguar XK120 OTS
No Quarter
Denmark
#4 Re: Clutch pipe/hose/bracket routing LHD
Post by No Quarter » Wed Feb 28, 2024 5:52 am
Perfect Tadek :bigrin:
Mikael
