#1 Assembling Britax Roof / broken edges
Posted: Mon Apr 01, 2024 4:30 pm
Morning,
I started assembly of my Britax roof, and now it seems I finally need a solution. The roof features 4 round alloy (Mazac? Monkey metal ?) edges. On two of them the tabs are broken.
There‘s almost certainly no source for these I guess anymore.
So, what would you say- I thought I should maybe try to have someone carve these for me from a solid block ?
Or, try to digitize them and print them from plastic ?
Or take what I have, remove as much metal from the remaining tabs and glue- in alloy tabs which are made to fit ? That seems to be the easiest way ?
Or forget about the tabs, and glue the edges on the roof using MS Polymer glue like Dekasil MS5 ? They will never come of and MS5 is elastic enough and UV stable afaik.
Kind regards,
Carsten, on the home straight this time.
Kind regards,
