#1 rear core plug replacement "in situ"
Posted: Fri Jul 12, 2024 1:22 pm
by PierreW
How to replace the rear core plug of the engine ? Mine has been ejected two days ago :twisted: big scare and cloud of steam....
is this possible without the great engine/gearbox "extraction" ?
Pierre
#2 Re: rear core plug replacement "in situ"
Posted: Fri Jul 12, 2024 1:57 pm
by DWW
I had one of those eject a while ago, it was the last one on the exhaust manifold side closest to the firewall, like you much steam and big scare, luckily I was close to home and after some cool off time managed to limp home. I managed to instal a new one in situ although it was not that straight forward as there is limited room and had to use a socket extension to apply between the core plug and hammer. I doubt it can be done in situ unless someone know better.
#3 Re: rear core plug replacement "in situ"
Posted: Fri Jul 12, 2024 3:54 pm
by PierreW
mine is the plug situated at the rear end of the engine parallel to the firewall ...so at the worst place :twisted: with very little access....
#4 Re: rear core plug replacement "in situ"
Posted: Fri Jul 12, 2024 4:26 pm
Hi....best option .ay be to llook at the expanding type of core plug with a center bolt to expand it..Steve
#5 Re: rear core plug replacement "in situ"
Posted: Fri Jul 12, 2024 5:24 pm
by DWW
Bloody good idea, first time I hear of it.....but will the rubber in it last?
#6 Re: rear core plug replacement "in situ"
Posted: Fri Jul 12, 2024 5:32 pm
Yes if you use Dorman plugs..also search Dorman copper expanding plugs..Steve https://www.mgaguru.com/mgtech/cooling/cool_105a.htm
#7 Re: rear core plug replacement "in situ"
Posted: Sat Jul 13, 2024 5:28 am
by PierreW
mgcjag wrote: ↑
Very, very, very interesting , thank you Steve :-)
#8 Re: rear core plug replacement "in situ"
Posted: Thu Jul 18, 2024 11:09 pm
by wagstefan
Dorman 568-011 - had to do the same. Take care when ordering over ebay.. Some selling one for the price of five.
Angus saved my life in that regard and gave me that hint.
But don't complain about spending 2 hours of trying to get bolts back in place for the rear engine/gearbox support bracket. I almost lost my mind....
Good luck!
#9 Re: rear core plug replacement "in situ"
Posted: Fri Jul 19, 2024 6:22 am
by PierreW
@ wagstefan
I ordered 5 in the US 3 days ago Thanks :wink:
#10 Re: rear core plug replacement "in situ"
Posted: Fri Jul 19, 2024 11:03 am
by david muir
Are these Copper plugs available in UK?
#11 Re: rear core plug replacement "in situ"
Posted: Fri Jul 19, 2024 1:46 pm
by PierreW
I ordered mine on amazon Us because I didn't find them nowhere else...
#12 Re: rear core plug replacement "in situ"
Posted: Tue Jul 23, 2024 12:17 pm
by rfs1957
Hey Pierre,
If you get 5 and don’t need them all, would you sell me one perhaps ?
Sounds like a good thing to have in the tool-kit.
Thanks.
#13 Re: rear core plug replacement "in situ"
Posted: Wed Jul 24, 2024 12:27 pm
by david muir
is the plug on the rear of the block 1" in diameter ( as opposed to 1 5/8 " at sides)?
#14 Re: rear core plug replacement "in situ"
Posted: Wed Jul 24, 2024 2:38 pm
by Allrand
No it's the same size. There's a smaller one on the inlet side near to the rear corner & higher than the others.
