#1 early shell
Posted: Tue Jul 30, 2024 10:17 am
by dxke38
Hi all, does anyone know if these seatbelt mounts are original and if so what year would they have been fitted.
Many thanks
#2 Re: early shell
Posted: Tue Jul 30, 2024 1:40 pm
by Allrand
Original I think. Does your car have othe other mounting points in the side of the prop shaft tunnel & towards the rear of the quarter vent base? Fitted from sometime in '63, mandatory from '64 onwards.
#3 Re: early shell
Posted: Tue Jul 30, 2024 2:26 pm
by Heuer
Everything you need to know: viewtopic.php?p=150039#p150039
#4 Re: early shell
Posted: Wed Jul 31, 2024 7:03 pm
by dxke38
Hi Randall, no it doesn't have the mounting points on the tunnel. The outer points are similar to these ones, on the floors.
#5 Re: early shell
Posted: Wed Jul 31, 2024 7:11 pm
by dxke38
David, the mounting points appear to be original but are obviously different to later types. I wondered if they were factory or fitted by the original dealer as were footwells to some early cars.
#6 Re: early shell
Posted: Thu Aug 01, 2024 7:47 am
by Allrand
What model is it? My 64 fhc has all the correct mounting points as per the sb's.
#7 Re: early shell
Posted: Thu Aug 01, 2024 11:39 am
by dxke38
Randall, its a very early flat floor fhc which I have been trying to gather information about for a long time to gain registration.
#8 Re: early shell
Posted: Thu Aug 01, 2024 1:02 pm
by Allrand
Interesting that it has the mounting points in the floors, possibly had floors replaced but they certainly look factory. Does it have a body no. tag?
#9 Re: early shell
Posted: Thu Aug 01, 2024 5:23 pm
by dxke38
No Randall, it doesn't, hence the original question. I've previously posted pictures and asked for info on this car but still keep finding little odd details that keep me thinking. Some details made it seem like a 61 car but others 62. Never seen seatbelt points like these though. I have been working on the mechanical side but havent had time for the shell untill now and don't want to go too far without more info.
#10 Re: early shell
Posted: Fri Aug 02, 2024 7:27 am
by Allrand
Derek the seat rail mounting points could also tell you something, the earlier ones had shorter rails thus the mounts were closer together. Check out Maikel Lemke's videos on original E-types.
#11 Re: early shell
Posted: Fri Aug 02, 2024 10:43 pm
by Dave K
Don't know if this helps, my November 1961 OTS had seatbelt mounting points on the tunnel and on the floor by the outer sill. It was only fitted with lap belts when got it. Things changed quickly with these early cars so you can never be sure from one week to another what was standard fit.
I fitted brackets inside the boot so I could have 3 point seatbelts.
#12 Re: early shell
Posted: Mon Aug 05, 2024 7:29 pm
by dxke38
Hi Randall, you were right, the seat mounting points are closer together for shorter rails. Thanks for the tip, unfortunately the car didn't come with the early seat rails.
Hi Dave, interesting that your car had the belt mounts in Nov 61. I hope that means my shell is earlier than that but who knows. Thanks for the info.
#13 Re: early shell
Posted: Thu Aug 08, 2024 1:32 pm
by mtnjag
My early 62, Oct/Nov 61 I think production, flat floor, LHD, No Seat Belt mounts.
Appears to conform with info posted by Heuer.
