Fitting MK 2 engine into an 4.2 S1 e-type?
ysmalkie
Poland
#1 Fitting MK 2 engine into an 4.2 S1 e-type?
Post by ysmalkie » Mon Aug 12, 2024 7:24 pm
I saw a S1 4.2 in a friendly workshop the other day with what appears to be a Mk 2 engine - the sump front and rear are wider.
Does the engine fit right through or does it require modifications? It definitely has a non standard exhaust arrangement...
Tadek
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
#2 Re: Fitting MK 2 engine into an 4.2 S1 e-type?
Post by abowie » Mon Aug 12, 2024 9:38 pm
I'm pretty sure you'd need an e Type sump without modification to the engine frames and reaction plate.
#3 Re: Fitting MK 2 engine into an 4.2 S1 e-type?
Post by Gfhug » Tue Aug 13, 2024 7:59 am
Aren’t the carbs different for a Mark 2 than an E Type? Unless correct manifold and carbs have been fitted I believe they would hit the bonnet.
Dawnpatrol
#4 Re: Fitting MK 2 engine into an 4.2 S1 e-type?
Post by Dawnpatrol » Mon Aug 19, 2024 6:24 am
What aspect made you think it was a MK2 engine?
Mike
Michael
1961 OTS LWE, 1965 OTS, 1966 FHC.
#5 Re: Fitting MK 2 engine into an 4.2 S1 e-type?
Post by mgcjag » Mon Aug 19, 2024 7:44 am
When you say mk2 engine what are you actually refering to..the complete unit with all ancillary or just the block.
Plenty of E types with 3.8 and 4.2 blocks from other models fitted..... sumps. heads carbs and manifolds need some thinking about....Steve
#6 Re: Fitting MK 2 engine into an 4.2 S1 e-type?
Post by Series1 Stu » Mon Aug 19, 2024 11:29 am
Also, Mk2's only came with 2.4, 3.4 & 3.8 litre engines so, if it was a 4.2, it was from a different model.
ysmalkie
Poland
#7 Re: Fitting MK 2 engine into an 4.2 S1 e-type?
Post by ysmalkie » Thu Sep 05, 2024 10:52 am
I am so sorry - this is what happens when you go on vacation without a laptop...
Anyway, the sump is a mk2 sump (I beleive) it's wider in the front and back.
What's curious is that the exhaust system is made to fit around the sump. On top, it really nicely bent and routed around.
If the car is still there, I will try to take some photos.
Tadek
Tadek
Jaguar XK120 OTS
#8 Re: Fitting MK 2 engine into an 4.2 S1 e-type?
Post by politeperson » Fri Sep 06, 2024 8:55 am
If you have a sump with wide "wings", the wings can be cut off pretty easily and re-welded on, to make the sump flat like an E type one.
The last time I did one was about 5 years ago, I cut an alloy XJ6 sump, and made the patches out of the left over bits.
A local engineering shop charged me £25 to tig weld the patches back on, to make it more E type style.
Saved me buying a new sump. It didn't look too bad at all.
I think I had to change the oil pick up pipes however.
