#1 Starter motor not engaging (inertial type)
Posted: Fri Aug 23, 2024 10:41 am
by PierreW
For those to whom this has already happened, here is a solution to avoid having to dismantle everything. Just drill a hole of about 4-5mm on the top of the clutch bell as pictured. This will allow you to inject lubricant on the starter pinion assembly with an aerosol can. I used a Teflon spray....miracle! I had to make an extended drill bit to get there. No problem!
Perhaps there is another location for the hole from below ...I didn't try
Hope this can help....
